over fueling
over fueling
Postby longchris » Sun Aug 09, 2009 12:16 pm
hi guys i have a 185 gt4 it has a power flow exhaust apexi filter ct20b and a cc i fitted an air fuel gauge and it right to the end of rich under hard driving so i took the pulgs out they are black what is a cheap safe way to lean out the fuel
longchris
Postby Insanity-74 » Sun Aug 09, 2009 3:09 pm
GT4s run rich...its just one of those things...better that than running lean, getting det and blowing the engine.
Saying that make sure the MAF sensor is clean and working correctly.
Insanity-74
Postby longchris » Sun Aug 09, 2009 11:05 pm
very true mate i will check it out at the weekend
longchris
Re: over fueling
Postby Gary ST165 » Sun Aug 09, 2009 11:48 pm
longchris wrote: what is a cheap safe way to lean out the fuel
cheap? er nope.
adjustale fuel pressure regulator & wideband oxygen sensor & datalogging
... ijust the start, ideally the car is screaming out for reprogrammabe 21st century engine management
ST165 turbo 4WD
Gary ST165
