Knock sensor problem
Postby pinoyGT4 » Thu Sep 24, 2009 4:27 pm
my CEL turns on whenever i hit 2,300rpm.. then i can feel a sudden retardation from the car's performance..
i checked the error code with the help of a reputable mechanic here, and it says knock sensor...
hmm...
so i then replaced my knock sensor with a new one.. still, the problem persists...
then my old knock sensor was put on a 4age 20v BT with a knock sensor problem too but it worked well meaning my old sensor wasnt busted..
what do you guys think i can do to isolate the possible problem that triggers the knock sensor error? :)
Making your car track worthy is making it more than road worthy
www.grupotoyota.com.ph
pinoyGT4
Postby Mafix » Thu Sep 24, 2009 5:14 pm
BAD WIRING
Postby siralys » Fri Sep 25, 2009 12:53 am
yup, I had to fix mine when I pulled my motor. at the worst just run a shielded wire from the sensor back to the ecu
2003 hyundai santa fe- daily driver
1995 vw passat vr6- modded wagon- sold
1988 celica alltrac- in parts finding mode
siralys
Postby pinoyGT4 » Fri Sep 25, 2009 1:21 am
Mafix wrote:BAD WIRING
oh man.. you think so?
i had my car converted coz it came from japan RHD and here in the philippines, cars are LHD...
i guess i have to ask my mechanic to re-wire it then..
but any other problem that could trigger the said error?
@siralys: so you just ran a shielded wire from the sensor, did just that fix the problem?
pinoyGT4
Postby gearhead313 » Thu Oct 15, 2009 11:50 pm
oh lord, the knock sensor woohs... i've gone through a ton of headaches fixing this. search and you'll see. DEFINITELY change the wire.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby pinoyGT4 » Thu Oct 22, 2009 10:06 am
gearhead313 wrote:oh lord, the knock sensor woohs... i've gone through a ton of headaches fixing this. search and you'll see. DEFINITELY change the wire.
damn.. i guess i really have to then... aright..
ill just fix my rack n pinion problem.. :(
pinoyGT4
