Fuel pressure too low
Postby camry90 » Wed Oct 21, 2009 11:53 pm
Ok this is what I have
walbro intank
bored out fuel rail
aeromotive fpr(bypass)
when It idles, the pressure is at 42psi and even if I turn the screw, pressure won't go up... How come? Do I have to set it at high voltage? And how would I do that?
camry90
Postby GrpAGT4 » Wed Oct 21, 2009 11:57 pm
You need to replace the fuel pump relay with a jumper to run it in constant high volt mode. There should be a write up somewhere about it. Pretty easy mod mate :)
GrpAGT4
Postby klue » Thu Oct 22, 2009 12:55 am
what injector are you using, and why do you want more than 42 psi?
Postby camry90 » Thu Oct 22, 2009 2:56 am
klue wrote:what injector are you using, and why do you want more than 42 psi?
i have the stock one that was cleaned by RC engineering
i want to follow what ATS did. they modded the stock FPR to make 50+psi to make it seem like bigger injectors.
camry90
Postby camry90 » Thu Oct 22, 2009 4:16 am
i tried to search but i can't find where it shows me how to bypass the fuel pump relay. can someone help?
camry90
Postby GrpAGT4 » Thu Oct 22, 2009 6:01 am
All you do is take 2 spade connectors, join them too about 3 cm of decent wire then brige two of the connectors in the fuel pump relay socket. I had it on my car but i took the walbro out cos it was friggan noisey. I think it was bottom left to top right in the socket. Not 100% though. was a while ago.
GrpAGT4
Postby bozo-merlin » Thu Oct 22, 2009 6:10 am
or try to put a paperclip betwenn B+ and FP on diag plug
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby AvivB » Thu Oct 22, 2009 11:49 am
Here are the schematics, let me know if you need something more.
Aviv.
/Aviv
('92 ST182RC 1/1 :-) )
AvivB
Postby camry90 » Thu Oct 22, 2009 5:23 pm
Aviv.:
Thanks ofr the schematics, but i have to jump / bypass which pin on the relay socket?
camry90
Postby AvivB » Thu Oct 22, 2009 6:46 pm
Pin 1 & pin 4 of the "fuel pump control relay" on the upper left corner of the first photo.
This will hold the pump to run at max power all time.
/Aviv
AvivB
