CODE 53 issues
CODE 53 issues
Postby shadowlife25 » Thu Oct 22, 2009 10:59 pm
So my 91 AT is throwing code 53 for the last couple weeks...
I purchased another ecu from DarthRipley (Thank You!) and let it run in the car, but the issue came back.
I also tried my JDM ecu with the same result.
According to the BGB CODE 53 is a fault in the knock control circuit in the ecu itself. Hence why I purchased and installed another one that was known to be good.
It simply is not possible that all 3 ecu's are bad.
I have also checked the wiring with my dvom and everything appears to be fine.
Any thoughts or suggestions?
I'm a bit stumped, as CODE 52 is able to detect a wiring fault or bad knock sensor, but it is only triggering CODE 53.
Your help is appreciated.
- Mario
- Mario
Postby built2run » Sun Nov 01, 2009 8:51 pm
i had a similar issue you might try to re-wire the knock sensor. i did this and it stopped the code 53(i had both 52 & 53) you do have to use shielded wire you can get it at radio shack and at most sterio shops.
ST165, black: parted and gone
ST165, white: sold to friend
