Bad Fuel Mileage ST185 O2 sensor?
Postby GrpAGT4 » Sat Oct 31, 2009 8:26 am
Hey,
Ive been getting bad fuel mileage since i bought my car. I get roughly 450kms to a full tank (280 miles) It has a 68 litre tank. The car seems to run well. I run it about 17 psi @ WOT. Has anyone exprienced bad milage as a direct result of a bad O2 sensor? I ask because everything else seems ok. Ive checked the timing and ect and all seems ok. I dont actually have a air/fuel meter or anything though.
GrpAGT4
Postby Corey » Sat Oct 31, 2009 5:55 pm
There have been a few recent 02 sensor threads on this subject.
Yes its possible. But seeing as you are running 17psi.. 450km/tank sounds acceptable. :shrug:
If its never been replaced before, you can get a new one for $40 without connector. Probably couldn't hurt to replace it if its as old as the car.
Cheers
Corey
Corey
Images: 50
Postby Rick89GTS » Sat Oct 31, 2009 6:07 pm
Does the 185 have a 69L tank? The 165 tank size is only 60L.
Rick89GTS
Postby GrpAGT4 » Sun Nov 01, 2009 12:11 am
yeah Rick. both the st185 and st205 have the same tank which is 68 litre. So you think with that boost 450kms is acceptable? I thought it seemed a bit high.
GrpAGT4
Postby tintman22 » Sun Nov 01, 2009 4:21 am
450 kms a tank at that boost level seems a little low, I usualy get 500km to 61 liters on my ST205. Are you running premium gas? Try running a fuel system cleaner, its cheap and will help. Also when is the last time you did a tune up?
1990 Toyota Celica GT4 (write off )
1992 Toyota Celica GT4
1994 Toyota Celica GT4 Sold
1993 Toyota Celica GT4 Sold
"Power is nothing without control"
tintman22
Postby GrpAGT4 » Sun Nov 01, 2009 8:56 am
I have a st205 tank fitted, you sure its 61 litres? Cos mines 68 litre. Also yeah i run 98 octane fuel. Does that fuel system cleaner stuff actually work?
GrpAGT4
Re: Bad Fuel Mileage ST185 O2 sensor?
Postby Gary ST165 » Sun Nov 01, 2009 9:47 pm
GrpAGT4 wrote:Hey,
sounds about right
Has anyone exprienced bad milage....
yep!
best i manage of late in my RC on a long motorway run, constant (off boost) 65 mph, covered 280 miles on 45 litres BP ultimate 98
28.2 MPG
10 Km per litre
Averaging £0.173 GBP per mile
i usually get 22.2 MPG by giving it death. :| :cry: :cry:
ST165 turbo 4WD
Gary ST165
Postby Tiki_man » Mon Nov 02, 2009 3:09 am
I've checked my 165 several times. When I first got it I was only getting arround 21.4 mpg in mixed driving. Now after full tune-up and a K&N drop in filter I'm getting arround 24.9 mpg. Tune-ups do make a difference lol. I'm hoping to redo my complete exhaust soon and see a few more mpgs.
Remember the 6 P's: Proper Planning Prevents Piss Poor Performance
Tiki_man
Postby Rick89GTS » Mon Nov 02, 2009 4:45 am
GrpAGT4 wrote:yeah Rick. both the st185 and st205 have the same tank which is 68 litre.....
I just checked the owner's manual. For the record, the 165 has a 15.9 gallon/60 litre tank, not 68 litre.
Rick89GTS
Postby GrpAGT4 » Mon Nov 02, 2009 5:02 am
Yeah man, i said 185 and 205 :P I only know cos i had a hole in my 185 tank and could only source a 205 tank and toyota have them down as the same part number.
'91 ST185 GT-FOUR Grp A Rallye
GrpAGT4
Postby Rick89GTS » Mon Nov 02, 2009 5:21 am
^Oops, I misread. My mistake :oops: Hmmm, I wonder if the 205 tank would fit the 165....
Rick89GTS
Postby Tiki_man » Mon Nov 02, 2009 11:55 am
Hhhmmm really? I thought it was much smaller than that. When I fill up I can normally only get arround 12-12.5 gallons. Maybe I'm just not getting it as low as I could lol.
Tiki_man
Postby gt4tified » Mon Nov 02, 2009 9:37 pm
Pardon my french, but what does a max. boost level have to do with gas consumption. I could set my boost to 25 or even 30 psi and get consistent mileage.
It all comes down to driving style......you like to change gears like an F1 driver....you burn more gas, you like to keep high rpm's in mid gears rather than cruise in higher gears......you burn more gas, you like to go to the grocery even under WOT at 17 psi...you burn more gas.
Gas consumption has nothing to do with your max. boost level, by itself anyway. :wink:
gt4tified
Images: 5
Postby TRDcelica90 » Mon Nov 02, 2009 10:03 pm
the best i get 470kms and that is pretty good as far as im concerned.. most gt-fours on Ozcelica are getting 420-450kms to a full tank on 98..
You surely didnt buy the car as a daily to save money so 450km is pretty good!
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby tintman22 » Tue Nov 03, 2009 5:07 am
GrpAGT4 wrote:I have a st205 tank fitted, you sure its 61 litres? Cos mines 68 litre. Also yeah i run 98 octane fuel. Does that fuel system cleaner stuff actually work?
Sorry I am not saying thats it is 61liter tank, thats just how much gas I have used when i usally fill up. If you run 98 Octane then your fuel system sould be preety clean. Disonect the rubber from the intercooler to the throttle body and look for carbon build up( crank the throttle open). If its dirty spray it out with throtle cleaner.
tintman22
Users browsing this forum: Baidu [Spider] and 2 guests
