Apex-i SAFC 2
Apex-i SAFC 2
Postby pinoyGT4 » Tue Dec 22, 2009 11:52 am
anyone tried or have proven feedbacks about this product on our tracs? particularly on a JDM 185, 2nd gen GTE... :D
someone's selling one here that's quite in the budget.. if it will bring good gains to my car than just boring a hole in my pocket, then ill get it.. :D
Apex-i NEO is a bit expensive and basing from the other thread here, nobody replied to it.. so im guessing nobody has feedbacks about it.. :bangshead:
and im not that die hard racing guy yet to venture into emanage blue or ultimate what more stand alones.. hehehe!
so there.. any help is appreciated.. :D
Making your car track worthy is making it more than road worthy
www.grupotoyota.com.ph
pinoyGT4
Re: Apex-i SAFC 2
Postby Speedricer » Thu Dec 24, 2009 4:04 am
I had one on my old motor setup. Be very careful tuning it. A wideband is a must to have lasting success with the tune and a dyno tune will get the most out of it.
They are a nice unit for the price.
92 ST185 White
3" full exhaust
Megan Racing Springs
FMIC
st215 swap
Speedricer
Images: 8
Re: Apex-i SAFC 2
Postby pinoyGT4 » Thu Dec 24, 2009 3:54 pm
Speedricer wrote:I had one on my old motor setup. Be very careful tuning it. A wideband is a must to have lasting success with the tune and a dyno tune will get the most out of it.
did you produce more power with this unit? and should i still be using MAF after installing this? :D
pinoyGT4
Re: Apex-i SAFC 2
Postby bccentaur3 » Thu Dec 24, 2009 5:42 pm
You can't ditch the afm with a piggy such as the safc. If you get a wideband it will help with tuning.
bccentaur3
Re: Apex-i SAFC 2
Postby pinoyGT4 » Thu Dec 31, 2009 2:24 am
bccentaur3 wrote:You can't ditch the afm with a piggy such as the safc. If you get a wideband it will help with tuning.
thanks brah..
pinoyGT4
Re: Apex-i SAFC 2
Postby Speedricer » Mon Jan 04, 2010 6:40 pm
You can lose the afm with a HKS vpc (vein pressure controller). Or go to the 205 ecu
I saw ok power gains but I was not tuning correctly.... Tune on a dyno
92 ST185 White
3" full exhaust
FMIC
st215 swap
Speedricer
Images: 8
Re: Apex-i SAFC 2
Postby CSAlltrac » Tue Jan 05, 2010 12:23 am
SAFC2s are crap........I just took mine out of my car, it was causing all sorts of issues. Alltracs and SAFC2s dont mix.
Re: Apex-i SAFC 2
Postby 6strngs » Tue Jan 05, 2010 7:59 am
If you're gonna do, apparently you are only supposed to use it to add fuel, not subtract it, or else it messes with your timing. Read the Power Primer if you haven't already.
Anyway, I've used the SAFCII and the neo, and I have to say I liked the Neo a lot more. You could adjust at more RPM points and in 50 RPM incriments instead of 100 (or was it 200?) rpm incriments. And just the overall display and everything was way nicer. SAFC II gets the same job done though if you don't care about aesthetics.
94 Celica GT - Sold
00 Celica GTS - Sold
88 Alltrac ST165 - Sold
04 Subaru WRX - Daily drive/fun car
69 Pontiac LeMans - project car
6strngs
Re: Apex-i SAFC 2
Postby pinoyGT4 » Tue Jan 05, 2010 10:03 am
CSAlltrac wrote:SAFC2s are crap........I just took mine out of my car, it was causing all sorts of issues. Alltracs and SAFC2s dont mix.
why? what sort of issues?
i really wanna know.. :D
6strngs wrote:If you're gonna do, apparently you are only supposed to use it to add fuel, not subtract it, or else it messes with your timing. Read the Power Primer if you haven't already.
thanks for the info.. :D
pinoyGT4
Re: Apex-i SAFC 2
Postby gearhead313 » Tue Jan 05, 2010 1:00 pm
I had great luck with mine. Worked flawlessly and gave me a knock monitor. Super useful!
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Re: Apex-i SAFC 2
Postby CSAlltrac » Tue Jan 05, 2010 1:33 pm
The only use I got out of mine was the monitoring. other than that it had me running lean for some reason no matter how many points I added, maybe it was just my car , It was also pulling knock and O2 code about every week, hasent pulled it since i yanked it. its running alot better without it.
Re: Apex-i SAFC 2
Postby 88st165 » Tue Jan 05, 2010 5:09 pm
There are some people on the mr2oc that run the safc to pull fuel. They use the added timing as an advantage and supplement the missing fuel with lots of meth. Agreed that it is very risky esp if you meth fails then you will likely lose your motor. But if you have fail-safes in place then its feasable.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Re: Apex-i SAFC 2
Postby gearhead313 » Wed Jan 06, 2010 1:37 pm
I remember working with this a while ago on my old 165. If you know where you are pulling your fuel down into, you can look at the stock maps and plot where the timing is going to go. I might have the maps somewhere still for reference.. You would ideally log total timing to see before and after.... i've held a timing light to cars on the dyno before which does the same thing.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Re: Apex-i SAFC 2
Postby pinoyGT4 » Sun Jan 10, 2010 5:07 pm
wew!
it was a damn good idea to ask around here before i bought the SAFC-2.. hahaha!
well, from the feedbacks, i think most had a hard time huh?
well, ill still look at the good comments about it.. but as of now, as a student, i cant afford to blow my engine........yet.. :lol:
ok, follow up question..
if ever i still push thru with it, should i pair with with ITC?
pinoyGT4
