AFM is sensitive to mounting aliment!
• Page 1 of 2 • 1, 2
Yesterday I discovered how much the AFM is sensitive the the way you put it.
I'm still in shock from this discover...
Specially since I saw quite a lot of photos with the AFM installed standing on the side but cannot find any post related to that!
When I installed the RC engine in my ST182, I had an open air-filter so I turned the AFM 90 degrees (the connector points up) to save some space.
Since then, I had a problem that the mixture is so rich you can smell the unburned fuel coming out of the exhaust pipe and it barely can run above 4K RPM.
While trying to figure out what causing the rich mixture, I've replaced almost everything (ECU, AFM, coil, plugs, spark cables, ignitor, O2 sensor, you-name-it) and the problem stays...
Eventually, I patched the AFM to adjact
Last Sunday, I've installed the original air-box back (because I've decided that there is no point to give the engine hot air...) and and the AFM in the original position (connector points backward).
Suddenly, I had verrrrrry lean mixture, so I removed the patch from the AFM and I didn't believe, all the rich problems disappear!!!.
So today, I did a test (because my friend claims that its because of the air temperature), I put back the open-air filter but left the AFM in the original aliment and it still works perfectly good.
When I just turned the AFM 90 degrees and all the rich problems are back!.
Bottom line, AFM is VERY sensitive to mounting aliment!
All of you who installed the AFM on the side but use 3rd party ECU which calibrated to your setup probably didn't notice that, but what about all the others who use the original ECU?
And now a question, did I'm an idiot and blind to miss all the threads about this or there was no thread on that and you're in shock like me?
/Aviv
('92 ST182RC 1/1
('92 ST182RC 1/1
AvivB - Gold Member
Re: AFM is sensitive to mounting aliment!
lol where have you been?
- Mafix
- Gold Member
mine is on a 90 degree angle but my plug is pointing down, notice absolutely no probs..
i run stock ecu too.. ill might have a play with it and see.
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90 - Club Member
Mafix wrote:lol where have you been?
What do you mean?
I'm reading this board for 2 years now and I don't recall anyone mentioning that...
Also, when I had may post about running super rich, no one offer me to check that...
/Aviv
('92 ST182RC 1/1
('92 ST182RC 1/1
AvivB - Gold Member
i had always thought that was common knowledge?
90 fix that issue. unles your AFM is screwed up it won't read correctly that way.
- Mafix
- Gold Member
I have 2 of them, one that I patched in the past and another one sealed (one from RC and the 2nd from CS)... both act the same...!
Mounted in original position, everything is ok and when mounted in 90 degree the mixture is super rich.
/Aviv
('92 ST182RC 1/1
('92 ST182RC 1/1
AvivB - Gold Member
um, mine is at ninety degrees with stock ECU, what am i missing here...?lol
White 1995 BMW M3
Black '90 st185 Sold :(
Landon - Established Member
hmmmmmmm....
ill try to move my AFM a bit...
i didnt notice if it was at 90deg when i put on an HKS filter.. hmm..
maybe thats why im running rich.. hmm..
- pinoyGT4
this is why the weight of the door in the afm opens more when its hanging down i seen so meany pics were people have done this .
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
- esracing
Hmmm, this could be the answer to my running rich problem too! I'm a little confused about how its supposed to be oriented... I bought it with an aftermarket intake so i'm not sure what the original setup is like. Can anyone post a pic of how it should be?? That would be awesome
1990 All-WAC
- Parkins
Here are some photos belongs to members on this board:
Right aliment without the original air box:
... and with the original air box:
and lots more on this thread:
http://www.alltrac.net/phpBB2/viewtopic.php?f=6&t=17324
/Aviv
('92 ST182RC 1/1
('92 ST182RC 1/1
AvivB - Gold Member
Mine is on its side with the plug pointing in the down direction , vehicle starts , runs and idles perfectly and i get no smell of unburnt fuel . it burns cleaner than my GT .
Kcman91gts - Club Member
I never try it when the connector points down... but when it points up, I get nightmare...
/Aviv
('92 ST182RC 1/1
('92 ST182RC 1/1
AvivB - Gold Member
Kcman91gts wrote:Mine is on its side with the plug pointing in the down direction , vehicle starts , runs and idles perfectly and i get no smell of unburnt fuel . it burns cleaner than my GT .
Im in the same boat, Im on my first real tank of gas to recheck my mpg. Im going to pay attention to that and do some testing also. Probably move it back temporarily to see how it acts and then go from there. I dont feel like its 100% so maybe that will help.
Mike
88 Alltrac-Light Duty
92 Pickup-Hauling Duty
97 Supra-Dust Collection Testing Device
98 GS400-Wifey
07 GX470-Daily
98 GS400-Wifey
07 GX470-Daily
97JZA80 - Club Member
