Apexi power fc
Apexi power fc
Postby ally » Fri Jan 15, 2010 4:17 pm
Hi have purchased a second hand apexi power fc ecu serial number sw21 9811 0026 not sure if it will my 1991 jdm st185 was told by the bloke i bought it off it would . Any help would be appreciated
ally
Re: Apexi power fc
Postby Gary ST165 » Sun Jan 17, 2010 12:24 am
i don't know if sw21 code relates to rev1 or rev2 mr2 turbo. so my guess is that you have might have an "AP engineering" AFM version. they are plug n play and available as either
revision 1 (early spec '89 - '91 ST185)
or
revision 2 (late spec August '91 - '93 JDM ST185).
my 1991 jdm st185
>>> 1991 was change over year for minor ECU revisions.
what build month and year is your car, ie what frame number ? > higher or lower than 15446, will determine which ap version you need for pnp. otherwise you might have to do some minor repinning
Air Flow Meter compatible "AP Engineering" modified versions exist for (rev1 & rev2) '89 - '93 3sgte
vs.
MAP sensor compatible revision 3 versions '94 -'99 3sgte
MAP sensor compatible AP Engineering modified and ST205 specific "charge cooler control" version for '94 - '99 3sgte
.... i think i may have confused the issue further. :lol:
I would appreciate if you would take a picture of the label and undo the 4 screws to pop off the cover an take some pictures of the circuit board.
ST165 turbo 4WD
Gary ST165
Re: Apexi power fc
Postby ally » Sun Jan 17, 2010 8:19 pm
Hi Gary
From the uk myself up in the north east near Middlesbrough.Here is some pictures of what i have got. Think it may be an ap engineering unit what is the difference between standard and these units ? not sure what will i need to fit a maf? Not sure what month my car was made in will check tomorow but what pins might i need to change? Have not got a hand controller any idea which one i need? thanks again for your help. Just acquiring all the parts to build a 400hp gt4 motor. Sorry for all the questions.
ally
Re: Apexi power fc
Postby Gary ST165 » Sun Jan 17, 2010 9:32 pm
Hi Ally,
re: Subject: Apexi power fc
Its been ages since i looked into the various power fc models available for the 3sgte
search.php?keywords=jetro&terms=all&author=&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
i also did a quick search on my home forum: http://www.gt4oc.net/forums/search.php? ... mit=Search
basically the power fc was available as d-jetro and l-jetro versions. tbh i don't know for sure what yours is !!!!
To run 400 hp, you will need to bin the ST185 AFM anyway and use the Power FC with an external MAP sensor and Air Inlet Temp sensor.
You could try and get a FC Commander unit, but you would be much better off buying a FC-datalogit: http://www.fc-datalogit.co.nz/ for your lap top. It is far more configurable that teh in car commander.
Essentially you will be converting your ST185 to run using factory ST205 sensors or similar aftermarket ones.
Most of the info regarding rewiring and swapping pins can be found the MR2 forums. they call this the Rev1 & Rev2 conversion to Rev3
rev1 MR2 is pre August '91 = ST185 early spec
rev2 MR2 is post August '91 = ST185 late spec
rev3 MR2 = ST205
http://www.mr2oc.com/showthread.php?t=271464
http://www.biststone.com/coyote-mr2/how ... ogen3.html
sorry to be vague, i can't be of much help as i have never done this myself, only what i have read.
If i were you i would spend somee time on mr2oc.com and imoc.co.uk, and try search for your Power FC SW21 0098 number and see if you can find out exactly if it is a Rev1, Rev2 or Rev3 model.
http://www.imoc.co.uk/forums/viewtopic. ... light=sw21
etc
Good luck
Gary
ST165 turbo 4WD
Gary ST165
Re: Apexi power fc
Postby ally » Tue Jan 19, 2010 8:45 am
Thanks Gary for that info will have a good look at it
Found out my car is an early 1991 model frame no 14128
ally
