Question for owners with "wire-in" EMS
Postby gt4tified » Thu Jan 21, 2010 1:59 pm
How did you wire your ems? More specifically the injector harness, tps etc. Did you remove the old harness entirely and wire the ems harness in or did you just tap in to the relevant wires on the oem ecu connector?
I'm trying to decide the best way on wiring in my LINK LEM 5.1 ems. It is a used system that was on a 3sgte on a rally car, so the injector harness and tps is already wired.
Any help would be appreciated, thanks!
gt4tified
Images: 5
Re: Question for owners with "wire-in" EMS
Postby Mafix » Thu Jan 21, 2010 2:39 pm
depends on how much you value your stock harness.
Postby gt4tified » Thu Jan 21, 2010 3:33 pm
Mafix wrote:depends on how much you value your stock harness.
Aah. Well, in my case, not really that much since it was a hack job in the first place. So what should I do?
gt4tified
Images: 5
Postby Mafix » Thu Jan 21, 2010 5:33 pm
if that is the case, hack away!
Postby gt4tified » Fri Jan 22, 2010 1:32 pm
Sweeet! Thanks Mafix.
gt4tified
Images: 5
Postby ChrisD » Fri Jan 22, 2010 6:59 pm
Like I said, you could try to work something out with Zen Autoworks. He sells canada wide.
1988 ST165
1994 ST205 WRC
ChrisD
Postby gt4tified » Mon Jan 25, 2010 7:52 pm
Chris, thanks a whole heap!
gt4tified
Images: 5
