1 wire O2 sensor. P/N needed
Postby camry90 » Tue Feb 02, 2010 4:44 am
i have a JDM RC. my O2 has only 1 wire. which part number can i use to get one from toyota? also, which online O2 sensor store can i trust to buy a cheaper one but yet good quality?
camry90
Re: 1 wire O2 sensor. P/N needed
Postby Corey » Tue Feb 02, 2010 7:55 am
viewtopic.php?f=10&t=35502&hilit=gas
Part numbers are in there for a 1 wire denso O2 sensor on www.oxygensensors4less.com
Corey
Images: 50
1989 Toyota Celica
Postby Mafix » Tue Feb 02, 2010 4:50 pm
nice l1h1 there is only 355 bucks. not too bad
Mafix
Postby camry90 » Tue Feb 02, 2010 10:05 pm
Corey Darling wrote:http://www.alltrac.net/phpBB2/viewtopic.php?f=10&t=35502&hilit=gas
Part numbers are in there for a 1 wire denso O2 sensor on http://www.oxygensensors4less.com
you only gave the P/N for the 4 wire sensor, i need for 1 wire sensor
camry90
Postby Corey » Tue Feb 02, 2010 10:21 pm
Ya, sorry, thought I had posted both in that thread
Here you go 234-1053 for 1 wire with connector
234-1051 for 1 wire without connector
Corey
Images: 50
1989 Toyota Celica
Postby AvivB » Wed Feb 03, 2010 12:20 pm
I had a 1-wire O2 sensor when I used the RC ECU...
I used this one from here and it was fine for me: http://www.usautoparts.net/catalog/?N=11785+4294963638+1725&Ntt=W0133-1621628
/Aviv
('92 ST182RC 1/1 :-) )
"Life is not the fact that your heart is beating but the number of times you miss a heartbeat..." (www)
AvivB
Postby 5thgenbliss » Thu Feb 04, 2010 7:40 am
i posted the 1 wire part numbers and where to buy them in the RC part numbers sticky thread a while back check them out there.
Boosting with the '92 GT4 RC
5thgenbliss
Return to EFI Corner
