soon to try out diypnp
Postby built2run » Wed Mar 17, 2010 5:09 am
just as the topic says just wondering if anyone has any advice 4 me
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Re: soon to try out diypnp
Postby datajon » Fri Mar 19, 2010 8:37 pm
can't say i have any input to offer for the diy pnp, is it not a smartly box mega-squirt with a fancy plug, only down side, they don't seem keen using water tight enclosures like most other aftermarket ecu .
did run megasquirt on a gtfour st185 ver 1 with msextra code 0249 back in 2006 all da way to ms2 running later msextra code on gt4 st205 .
the early system had a few teething problems with dual VR setup but did make use running oem hardware. ran good, made strong power, great drive-ability for a cheap diy ecu. easy to map exceallant functions very easy to customize to fit any setup. deffo value for bang.
ms3 pro is out shortly, which offers many new features like onboard logging etc.
datajon
Postby datajon » Fri Mar 19, 2010 8:48 pm
worth a visit here : http://www.ms3efi.com/~msextra/feature-xref.html
taster
ms3 Image
Sequencer Image
not so keen on the double ended connectors concept :shrug:
they have even increased fuel and spark tables to 16 x 16 :) so with dual tables you can get close to motec table size. not bad for the money.
datajon
Postby built2run » Wed Mar 24, 2010 6:42 am
its based on microsquirt with a bunch of add ons and a msII looking board it comes with the stuff i am looking for so ya i hope they can eventually make some of the stuff for ms3 adaptable to the diypnp, and ya the fancy oem connector was the highlight for me as i have a st165
built2run
Postby built2run » Tue May 04, 2010 4:10 am
ok not like anyone cares but i got it and its mostly assembled i still have to make sure how i am doing the flatshift and launch control on it. it can do 2 maps so thats all i need all i need now is all my fuel stuff and off to 400 hp i go my goal is to have it hit peak power kinda high and my rev limit at about 7750. holy crap i can't wait!
built2run
Postby tw2 » Fri May 21, 2010 3:40 am
Sounds, good keep us updated, do you know what software is available for tuning? tunerstudio is great for MS1 and 2, not sure if it supports 3 yet.
Thomas, JDM 90 185, 06 350z
tw2
Postby built2run » Fri May 21, 2010 8:10 pm
not sure exactly, maybe just megatune for now. i can't do anything with the ms3 stuff but i am sure tunerstudio will work with ms3
built2run
Postby 88st165 » Fri May 21, 2010 9:31 pm
Awsome. I have been researching MS here and there. I want to run it on my 165 also but no funds at the moment. Keep us updated with your progress 8)
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby tw2 » Fri May 21, 2010 9:54 pm
I think tuner studio is a lot better than it used to be. It used to be free (and work fine) but now it is $40 which isn't much but hopefully that now accounts for something. The auto tune feature definitely makes it very easy to tune low/medium load and get off boost mapping sorted out. Obviously high boost should be done on a dyno.
tw2
Postby built2run » Fri May 21, 2010 11:08 pm
u guys want some pics of the pertially assembled unit?
built2run
Postby tw2 » Fri May 21, 2010 11:10 pm
Yeah, definitely.
tw2
Postby MXP_57 » Sat Jun 12, 2010 3:08 am
Does those diypnp work with the stock ignition system?
CEIKA Demo car 1987 ST165 JDM 1000kg/700hp http://ceikaperformance.com
MXP_57
Postby built2run » Mon Jun 14, 2010 7:54 pm
sorry guys been busy and what not, when i can i will post'em
built2run
