vacuum valve on st185
Postby aus jd 2703 » Fri Apr 09, 2010 1:33 am
ok guys im curious what this valve is its on the fire wall close to the right hand side (rhd) just near the brake booster. it has 2 wires and two vacuum lines and is spliced into the turbo pressure valve?
again its an australian delievered st185 and im trying to install a st205 engine and ecu.
any help on what it is and what it does would be great.
thanks guys
aus jd 2703
Re: vacuum valve on st185
Postby MWP » Fri Apr 09, 2010 3:25 pm
Damn, i cant remember what that one is for... maybe AirCon idle up?
It cant have been too important though, i removed it :P
Postby aus jd 2703 » Fri Apr 09, 2010 10:28 pm
well i wanna keep it unless the st205 doesnt need it :P
aus jd 2703
Postby aus jd 2703 » Thu Apr 22, 2010 9:58 pm
what is it? where should the vacuum lines run too
aus jd 2703
