Need help identifying ecu connector pins
Postby white91 » Thu Jul 15, 2010 12:04 pm
It's for the 22 pin ecu connector from a '92 st185rc. These are the only pins that do not match up with my US connector.
ECO, PSCT, CCO, ABS, FL, EGW
I've tried searching for RC wiring diagrams but none that I have found cover these in enough detail. I'm assuming the ECO is for the different AC and ABS is for abs. Would it be ok if I just plugged the US ecu 22 pin connector into the jdm rc ecu without modifying it?
'91 MR2 NA->T t3-to4e'd - sold
'97 VW GTI VR6 - sold
'01 MR2 Spyder - sold
'02 Subaru WRX - sold
'90 Celica Alltrac ST185 RC swapped: FOR SALE!
NYC Subway - Current :/
white91
Re: Need help identifying ecu connector pins
Postby phattyduck » Thu Jul 15, 2010 5:12 pm
Have you traced them out to see where they go?
Off the top of my head, I only remember EGW. Its the EGT/Cat temp sensor warning output, and can be left disconnected (especially if you aren't running the cat temp sensor!).
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby white91 » Thu Jul 15, 2010 5:43 pm
That's good news then. I'm sure one if the others would have to be for the electronic speedometer. I think I'll just try plugging it in and see what happens since all of the other pins line up (except the 6 that don't exist on my stock dash harness).
white91
