Can someone please advise on these fuel tables
Postby tw2 » Sat Sep 11, 2010 10:05 pm
I am slowly getting ready to take my car to get dyno tuned properly. I would like to get my fuel tables configured and do some low load, low rpm street tuning to get the car reliably mobile first.
I have been reading a few recent EFI tuning books which have helped a lot.
- How do the rpm and load spacings for my AFR and VE tables look?
- Does the target AFR table have appropriate values in it?
I would like to make sure these are as good as they should be before spending a lot of time tuning them.
VE fuel table
Target AFR value table for auto-tune function
Thomas, JDM 90 185, 06 350z
tw2
Re: Can someone please advise on these fuel tables
Postby MWP » Sun Sep 12, 2010 6:02 am
Target AFR table looks good.
Not sure about the VE table though.
Really need to get on the dyno to tweak that as every engine is different.
Postby tw2 » Sun Sep 12, 2010 6:38 am
Thanks, I have changed a couple of things in the AFR table, 15.7 is probably too lean to cruise. I have lowered it to about 15.0-15.2 and changed some other low load areas closer to 14.7.
The VE table numbers themselves are not very accurate and need a lot of futher tuning. It will be thrown on the dyno before too long. Do the rpm and load spacings look ok? I tried to give it a lot of low-mid rpm resolution since this is where things will be changing the most.
tw2
Postby Simba » Thu Sep 16, 2010 12:59 am
tw2 wrote:15.7 is probably too lean to cruise.
It's very lean and will lead to bad things happening, especially in a tip-in WOT situation from those AFRs. 15:0-15:2 is safe enough for lean cruise, after that you're risking a lot for a tiny increase in economy.
Lots of fast, loud things.
Simba
Postby sleeper » Thu Sep 16, 2010 8:46 am
Looks ok,
Not really shure what ems you have, but i think you have to many load points in the of boost area..
20-40-60-80-100 will do.. no need to have one every 10..
sleeper
Postby tw2 » Thu Sep 16, 2010 9:26 am
Thanks for the help. It is megasquirt 2 extra. Those load points are vacuum, 100 is 0psi. Boost is 100 to 250kPa.
tw2
Postby MWP » Thu Sep 16, 2010 11:12 am
Meh, i lean cruise at 16:1 with no problems.
As long as the engine doesnt ping with rapid throttle increase from cruise, youll be fine.
Going lean for a fraction of a second on transition isnt going to melt a piston.
Postby Simba » Thu Sep 16, 2010 3:13 pm
MWP wrote:Meh, i lean cruise at 16:1 with no problems.
Frankly, that's a hack of a standard and has no place in a proper EFI tuning discussion. "I do it and it hasn't blown up or melted yet" is generally the sort of advice to be wary of.
$2-3,000 for an engine rebuild buys a lot of gas, and the difference between a 15:1 and a 16:1 cruise is around 1-2 mpg at most. You're stressing the engine and running it much hotter than it needs to be run in order to realize a minuscule fuel savings and range increase. That is a ridiculous thing to suggest anyone replicate.
Simba
Postby sleeper » Thu Sep 16, 2010 8:09 pm
well, combustion temps are not higher at 16:1 than 15:1, they will actually be higher at 15:1 than 16:1... ( exhaust temp normaly is at top at about 14.2afr.. and get`s lower the more you lean it out due to lack of energy... ( fuel)
sleeper
Postby MWP » Thu Sep 16, 2010 10:10 pm
sleeper wrote:well, combustion temps are not higher at 16:1 than 15:1, they will actually be higher at 15:1 than 16:1... ( exhaust temp normaly is at top at about 14.2afr.. and get`s lower the more you lean it out due to lack of energy... ( fuel)
... this is true.
Postby ___Scott___ » Fri Sep 17, 2010 2:25 am
NOx formation correlates with combustion temperatures, so in the graph below you can get a general idea of what the combustion temperatures are going to do as a function of AFR by looking at the NOx curve:
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby tw2 » Fri Sep 17, 2010 5:57 am
Exactly, oxides of nitrogen only form in very high temperatures which is why most new cars run 14.7, some running that ALL the time (at a loss of WOT power obviously) to have optimum emissions, and reasonable (ie not the best absolutely possible) economy. Fuel has a cooling effect. The leaner you go the higher the combustion temperature and the more sporadic and non-uniform the burn is. The fewer and further between the fuel molecules are the more the mixture burns in little pockets one at a time = detonation. The question really is how high is safe, I am not going above 15.2. I want to try and get good economy but I also want excellent reliability and margin for error.
tw2
Postby Simba » Tue Sep 21, 2010 5:10 pm
The issue I was referring to is not EGT at lean AFR cruise. It's what happens when you transition from a very lean cruise to a tip-in WOT condition. Potentially very bad things.
There are a number of things to consider-- how much cam overlap exists? Is there a cat in the exhaust? What, exactly are the EGT and CHT temps in a particular application? How quickly does the fuel system and EMS in use react to load changes? Those metrics, and many more decide if a given lean cruise AFR is safe. "I do it all the time so it's safe for you" is irresponsible.
Simba
Postby MWP » Wed Sep 22, 2010 1:09 pm
So what bad things exactly?
I want to know what can happen that's that bad in the fraction of a second (ie, one or less rpm's) before tps pump enrichment kicks in.
If it's not knocking or getting high egt's, what's going to cause damage?
Postby cozmic512 » Thu Oct 07, 2010 3:06 pm
I have a few questions here. Is the lean cruise based solely on throttle position?
which translates to load? or is it simply rpm. Im not familiar with the way megasquirt is tuned.
I know you have afr's tuned for each cell based on rpm. what is fuel load %?
because the scale goes up to 250, and that makes no sense to me.
how can you have 250%. sorry about that, I think Im missing something.
regards,
Cory
92 ST185
cozmic512
