Megasquirt my ST205
Megasquirt my ST205
Postby Domspun » Fri Sep 17, 2010 1:52 am
I sold my C-One ECU and I want to use my Megasquirt I was using on my last race car(Mazda Protege with a KL-ZE). The setup was simple with my Mazda, but I don't know what will work with my ST205!? Anybody installed a MS on this engine?
Thanks!
Domspun
Re: Megasquirt my ST205
Postby MWP » Sat Sep 18, 2010 3:16 am
:rofl:
Did you see this? viewtopic.php?f=9&t=31249
ST205 isnt much different (not different at all?) to a ST185.
Postby Domspun » Sat Sep 18, 2010 12:43 pm
MWP wrote::rofl:
Did you see this? http://alltrac.net/phpBB2/viewtopic.php?f=9&t=31249
Yes, I checked that. The ST205 have no AFM, it use a MAP, the chargecooler have a pump, the distributor is different, the TB is different, etc. On my old setup, I was using the OEM distibutor with a ignition box, worked great.
Domspun
Postby MWP » Sat Sep 18, 2010 1:53 pm
Well you throw away the MAP sensor, run the W2A off ignition so its always on, TB is easy to fix.
In what way is the dizzy different??
Postby Domspun » Mon Sep 20, 2010 1:15 am
MWP wrote:Well you throw away the MAP sensor, run the W2A off ignition so its always on, TB is easy to fix.
I have to check again when my car come back from some repair. I have a spare disty from my ST185 and I wanted to use it on my ST205. Is all MR2/GT4 disty suppose to be the same??
Domspun
Postby tw2 » Sat Sep 25, 2010 9:05 pm
I am using a gen 3 TB on my gen 2 MS setup, they are identical in how they work, just follow my instructions for the idle up valve and you are good to go. The TPS is extremely easy to calibrate- open it, press calibrate, close it, press calibrate. No problems there.
No one can or would want to use the AFM with megasquirt. MS comes with an internal MAP sensor anyway so pull your stock one out and sell it for a crazy high price for someone wanting a gen 3 electronics swap. We all ditched our AFM as soon as we could.
Chances are your ignition system will not work or will be much to complicated just like the previous generations but no harm in trying... follow the instructions for general dizzy setup in the megamanual. Previous gens have trouble with noise filtering which is why no one has got MS to work with the stock system. I recently changed my dizzy cap on my gen 3 mr2. I did notice that the pick ups look a little different so you might be in luck. Otherwise get EDIS or coil on plug and be done with it- very easy.
IC pump??? you can set this up using a spare output pin, you can run it using any criteria you want, it can come on at a certain rpm/boost/coolant temp or any combination of anything you can think of.
What MS and board are you running and with what code? Hope this helps, otherwise flick through all 217 posts in the FAQ and hopefully most questions should be answered.
Thomas, JDM 90 185, 06 350z
tw2
Postby Domspun » Sun Sep 26, 2010 3:12 pm
tw2 wrote:I am using a gen 3 TB on my gen 2 MS setup, they are identical in how they work, just follow my instructions for the idle up valve and you are good to go. The TPS is extremely easy to calibrate- open it, press calibrate, close it, press calibrate. No problems there.
Nice post!! Thanks a lot. My main concern was ignition. Both my MS were V3.0 with MS1. As for the code, I do not remember. Now I sold them both. I will temporarily use a Greddy e-manage blue while I get another MS built. What do you suggest for the next one? MS2? Board V3.57?
Thanks!
Domspun
Postby tw2 » Mon Sep 27, 2010 5:17 am
I would go for MS2 extra on a 3.57 unless you have certain requirements. MS3 is out but from looking at the changes there is nothing there that I personally would take advantage of but it depends what and how you use you car. It is very expensive compared to the others although USB would be nice. If you get a 3.0 or 3.57 board you can upgrade to MS3 later anyway.
tw2
Postby gringo » Thu Feb 24, 2011 8:44 pm
if you are going to convert to distribuitor would you like to sell me your 4 coils ? part # 90919-02227 or 1 at least ?
gringo
