A'pexi PowerFC sw20-st185 ?
Postby RoAdbOy » Tue Sep 28, 2010 5:33 pm
Hello, will the PowerFC for 'SW20 gen2' fit the '5/1991 ST185 GT4' plug and play?
or what must be changed?
my st185 is not CS or RC, its an ATA intercooler 1991 ST185, and the PowerFC who i want buy is one for SW20 gen2.
thank you.
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
RoAdbOy
Re: A'pexi PowerFC sw20-st185 ?
Postby MrDB » Wed Sep 29, 2010 8:44 am
Its not plug and play but almost
You will need
Rev3 Mr2 turbo Igniter ( just plug in )
Rev3 Mr2 turbo Map sensor ( just plug in )
Rev3 Mr2 turbo MAT sensor (needs wires soldered in)
Rev3 Mr2 turbo IAT sensor (needs wires soldered in)
(ideally also 550cc injectors) it will run really lean until mapped if you stick with the 440s ( you can up the presure in rail if you need to drive to mapper/tuner. though and take it steady no boost)
you will need to repin the engine harness, and ditch the AFM. All very easy really some guides online search for rev2 to rev3 ecu conversion on mr2 boards. If your ok with electronics (basic) and a soldering iron its simples. im in the process of doing it now but im using a st205 ecu for now.
MrDB
Postby RoAdbOy » Wed Sep 29, 2010 2:16 pm
wooww :) thank you for the magnificent information. this was the answer who i needed.
Mehmet Ali Ovacikli
istanbul / TURKEY
RoAdbOy
Postby sentraman » Fri Oct 29, 2010 5:23 pm
May you can get a hold of CRW (Chicoraceworks) I know they can do some work to the power fc to have it work on 5th gen Celi or it might be ATS
04' Forester XT
sentraman
Postby Gary ST165 » Fri Oct 29, 2010 5:40 pm
NOT plug n play
gen 2 = sw20 is it rev 1, rev2, or rev3?
Use a GM 3 bar , or Apexi AVCR / denso 3 bar map sensor
Use a Bosch: Audi TT rapid response Inlet Air Temp sensor or the RIAT http://cgi.ebay.co.uk/Celica-GT4-RIAT-I ... 0716118792
ST165 turbo 4WD
Gary ST165
