Tachometer wire for 92 USDM/CAD St185
Postby cbrkp » Mon Nov 01, 2010 11:18 pm
Hey all,
so I'm installing a starter for 92 USDM/CAD st185 and I want to use wires inside the cabin rather then going into the engine bay and using the distributor coil wire as a tach wire.
Any ideas if any of the wires leads off the ecu pin outs can be used? or perhaps a wire behind the cluster for a tach wire?
thanks!!!
cbrkp
Re: Tachometer wire for 92 USDM/CAD St185
Postby cbrkp » Thu Nov 04, 2010 6:31 pm
got the info. no longer needed but for anyone who needs you can try "IGF" off the ecu as thats what I'll be using.
cheers!
cbrkp
