AEM EMS-4
Re: AEM EMS-4
Postby toayoztan » Wed May 30, 2012 2:19 am
Hm, I haven't heard but good stuff about the series/version 2 software of AEM, which is what this ems4 also uses.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: AEM EMS-4
Postby tubasteve » Wed May 30, 2012 2:30 am
running junes budget by the wife tonight. hope this works. 2.2 stroker next month.
-jr
tubasteve
Re: AEM EMS-4
Postby OutToWinPAHC » Wed May 30, 2012 10:52 am
tubasteve wrote:good to hear, im not worried about the sensors as they are dime a dozen at my shop. i was really worried about complaints about the tuning software, unreliability. this car will not really be street driven anymore, just had a hour talk with my engine designer(machinist). ordered some pistons and bottom end to play with on this setup. ill be ordering it this thrusday with the short harness. unless there is a reason i should need/want to go long.
-jr
The software is great, but like anything it takes time to learn. I used to mess with HP tuners, big stuff, and PowerFC before AEM and it was a bit of what he hell the first day, but once you get it going it's not bad.
As for the sensors when I do this I will use the dizzy and carry the setting from the other toyota files, but will use coil near dissy using a LQ coil pack, 3 bar GM map and IAT. Looking at the ECU pinout there is not a whole lot needed to be changed.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Re: AEM EMS-4
Postby tubasteve » Thu May 31, 2012 1:49 am
-jr
i purchased it.............i have all the sensors, ill be looking into the 4 coils idea soon, but no time soon. ive used hondata, messed around with the aem software back then trying to tune evos with this, but decided not to as my dyno time no longer free cause he sold the shop.
So NO ONE has installed this yet? or am i again having reading problems sober.(happens often)
-jr
tubasteve
Re: AEM EMS-4
Postby toayoztan » Thu May 31, 2012 3:33 am
Nobody on here has hooked it up to an alltrac I believe.
My friend has installed them on various cars at his shop though, and hasn't complained of any issues.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: AEM EMS-4
Postby tubasteve » Sat Jun 02, 2012 2:52 am
toayoztan wrote:Nobody on here has hooked it up to an alltrac I believe.
Bryan
if not t minus 2 weeks for me
tubasteve
Re: AEM EMS-4
Postby toayoztan » Sat Jun 02, 2012 3:25 am
You should make a brief pictorial :D
Are you using the 96" loom? I am going to. I want to just run fresh wires and rid of the OEM harness, it's too bulky, crunchy, old, etc.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Re: AEM EMS-4
Postby tubasteve » Sun Jun 03, 2012 2:11 am
toayoztan wrote:You should make a brief pictorial :D
Bryan
For now I'm doing it plug and play...i was about to say it's a 94 harness....st205... But no, i bought the adapter harness to go with other aem products. In the next 6 months I'll do the harness though. In going to use a crap clutch to break in the engine, then when i do the clutch I'll be changing fuel system, ignition system, install cams and turbo. Of which i will have all here within the next week, but need to pass smog first. And finish tweaking the chassi.
I'll do pictures, well the wife will.
-jr
tubasteve
Re: AEM EMS-4
Postby Akihero » Sun Jun 03, 2012 5:49 am
i saw this online thought it may be interesting
http://tuner-deals.com/aem-ems4-pnp-for ... -p-73.html
Akihero
Re: AEM EMS-4
Postby tubasteve » Sun Jun 03, 2012 5:44 pm
Good find, mine cost total was 700+ 100 for pnp harness.
-jr
tubasteve
Re: AEM EMS-4
Postby 88st165 » Sun Dec 02, 2012 9:41 am
I just wanted to bump this to see if there is any new info out there. Going to revive my 165 after all these years and was looking into using this ems.
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Re: AEM EMS-4
Postby Tecker185 » Fri Dec 14, 2012 1:38 am
I have one installed in my st185. A rough tune for 10psi and I like it so far. I'm waiting till spring for a 20psi tune.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: AEM EMS-4
Postby 88st165 » Fri Mar 01, 2013 6:01 pm
Bump again. Is this capable of running the stock ignition system or does it require a conversion to EDIS like megasquirt?
Black st165 - gone
88st165
Images: 2
Re: AEM EMS-4
Postby tubasteve » Sun Sep 22, 2013 4:20 am
Stock. Will finish tuning the next couple weeks.
tubasteve
Re: AEM EMS-4
Postby 88st165 » Tue Oct 01, 2013 2:49 am
Good to know. Still looking into this as an Ecu option. Looking forward to your results.
Black st165 - gone
88st165
Images: 2
