ST185 ECU 'unlocking" for 18psi?
Postby Jason88AllTrac » Wed Mar 30, 2011 9:14 pm
A friend of mine works for Toyota out in CA. He says he met a guy who worked as the FPE specialist for the ST185.
He said that some of the ECU's could be "unlocked" to run 18PSI maps by soldering a few things on the board. This was used for racing classes that required a stock ECU.
He said he was going to send me information as soon as he did the modification to a 1990 all trac ECU and put it in his MR2.
Does anybody know about this, or should I be thinking he's full of it?
Thanks,
Jason
White 88' ST165 :: Blue 88' ST165
Jason88AllTrac
Re: ST185 ECU 'unlocking" for 18psi?
Postby athousandleaves » Wed Mar 30, 2011 10:56 pm
Quite possible and very interesting but I can imagine that this would require more than a simple point-point soldering of a chip on board.
You would probably need another ROM that has the maps to fuel the car properly up to 18 psi properly - not to mention all the other things.
I'm very interested in this though so keep me posted!
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby celicat93 » Thu Mar 31, 2011 3:30 am
:evil:
celicat93
Postby MrDB » Thu Mar 31, 2011 8:49 am
Its well documented that the ecu doesnt have the maps inside to accuratly map to 18psi. so the mod will only if anything replicate a FCD ( fuel cut defender )..
Stock ecus are being hacked again though as we speak....
[url]http://www.twobrutal.co.uk/forum/showthread.php?15236-ECU-Code-Disassembly/page28&highlight=ecu+reprogram
[/url]
register for free to view :)
MrDB
Postby athousandleaves » Thu Mar 31, 2011 12:32 pm
iirc, the RC ECU is good to about 17.4psi before you fuel cut...
Also there are some other topics con the boards about unlocking our ECU on a regular 185 to get up to 16psi.
~correction~
90-91 ECU's are good to 12.5psi before fuel cut
92-93 ECU's are good to 15psi before fuel cut
RC ECU's are good to 17.5psi before fuel cut
Although I have read that all kouki ecu's are set for 17.5...
In my USDM 92 I ran 14psi quite comfortably last summer and never hit the cut.
1992 White turbo4WD
athousandleaves
Postby built2run » Sat Apr 02, 2011 4:27 am
orrrrrr u could just do away with fuel cut as sometimes the conditions are right enough to fail the engine as its cutting fuel. had it happen on my first block =( in a split second man
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby Mattyno » Wed Jan 25, 2012 6:51 am
Hi, I have forged engine and I installed CS Unit (89661-2B320) My friend also had a CS with a forged engine and ECU were 3 modes. Changing the position of a jumper on the HDD in the PC changing FC. The last is,''setting rally, in which the blown turbo 21PSI. I have a question, do you know what unit may have a number? It was only for Japan?
Thanks for answers.
Funny-Celica ST185 1990 @14psi, Blitz Nur Spec, Apexi AVCR, HKS BOV, FCD, XTD stage 3 ceramic clutch, KYB excel G+springs SPAX, PUR dure-flex, spark PULSTAR, Wide Band, Fuel Pump Walbro, EGR off, TVSV off, MSD, CPpistons, Eagle, ARP and more :)
Mattyno
Postby celicat93 » Wed Jan 25, 2012 6:34 pm
I was talking with a professor who works in my department at the U of I who has a 93 turbo MR2 that he bought new. He told me that he was at a car show back then that featured a one off special edition that had special specs and from what he described to me, it sounded like what we do with the FCD and a boost controller, achieving about 240hp. I would think if there were anymore "secret, hidden mods" in the 3SGTE, they would have pulled them all out with that demo car.
celicat93
Postby DudeMan » Wed Jan 25, 2012 7:17 pm
athousandleaves wrote:90-91 ECU's are good to 12.5psi before fuel cut
Kinda off topic but I've gotten to 17 psi in my 1990 and never hit fuel cut.. :shrug:
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby athousandleaves » Wed Jan 25, 2012 7:42 pm
Is your car a Canadian delivered 185 or a JDM import?
I was closing in on 18 psi when I last drove my car and blew out the turbo to manifold gasket but didn't hit fuel cut either.
I should just pull my ECU and run it on my workbench through different simulated psi ranges until I see fuel cut kick in.
1992 White turbo4WD
athousandleaves
Postby DudeMan » Wed Jan 25, 2012 9:46 pm
Canadian model.
I think I'm going to disconnect the turbo pressure sensor and use the vacuum port for my BOV instead.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby klue » Thu Jan 26, 2012 3:27 am
You dont need to "unlock" anything. The ecu has no idea what pressure its seeing. The turbo pressure sensor is solely used for boost cut. Weather is 5 psi or 20 the AFM does the fuel calculation anything over like 14 psi its squirting as much fuel as it can. Just hope it dont blow :P
Postby tubasteve » Fri Feb 03, 2012 3:11 am
I've noticed lazy computers...run 16 and no cut, on a cold night....it will cut at 12+
tubasteve
Postby Corey » Fri Feb 03, 2012 3:28 am
My 89 JDM fuel cuts at 14Psi
Corey
Images: 50
