HKS AFR Type-L ?
HKS AFR Type-L ?
Postby RoAdbOy » Sat Apr 23, 2011 10:11 am
hello, has anyone tried it before in a 3sgte?
''The HKS AFR is a fuel-adjustment device that regulates the air/fuel ratio by changing the airflow voltage output to the vehicles factory computer. The AFR was designed for vehicles that are lightly tuned (intake, exhaust system, etc.) and need only slight fuel adjustment. The 12 setting adjustment indicator allows the user to enrich or lean the stock fuel settings by approximately 1.0 A/R point in either direction (richer or leaner). Type-L is designed for vehicles that utilize an air flow meter.''
i wonder if this is a better choise as a SAFC for slightly modifications like intake/exhaust & more boost?
it looks very simple :)
Mehmet Ali Ovacikli
istanbul / TURKEY
