Help me fine the plug for the fuel pump resistor pack ASAP!
Re: Help me fine the plug for the fuel pump resistor pack ASAP!
Postby bozo-merlin » Mon May 02, 2011 6:48 pm
I had the same issue 3 years ago on a "GT2" (ST182 3SGE+FWD + 3SGTE) so i am not a genius, you have a lot of chance i read your post that's all :lol:
About your -8AN thinking
- no matter the ID hose for fuelling your engine : every FP (even a tired one) could push at least 29psi at idle (which is enough).
- no matter the ID hose for fuelling your engine : pressure will fall only when pump can't flow at the desired FPR+boost pressure and IDC are high
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Return to EFI Corner
