School me on the Apex'i SAFC
Postby underscore » Tue May 17, 2011 6:42 am
I've got one of these coming in the mail shortly, it was an impulse buy so I didn't really look into the specifics of using one with a 3SGTE at first. Now I'm reading that using something like this on a 3SGTE is more likely to blow up my motor than increase my power at all? Right now the car is bone stock aside from a boost gauge and soon a 3" exhaust and boost controller.
So to those of you who have used an SAFC or done more research than I have about them, can I safely gain some power by using it? Or should I just go and resell it right away because I'm more likely to blow my motor than anything else?
Thanks in advance.
Re: School me on the Apex'i SAFC
Postby MrDB » Tue May 17, 2011 7:40 am
TBH sell it on you will get little gains and you need dyno time anyway to tune it.. Only does fuel and looks pretty on your dash...
Altering the AFM ( fuel ) causes timing changes and thats how to blow things up if you go to made with adjustments...
MrDB
Postby RoAdbOy » Thu May 19, 2011 3:06 pm
i'm still use a apexi safc in my st185 gen2.
the most blow-up engine reason in 3sgte's is to lean it up more than -%10 point.
this will cause high ignition timing changes.
when you don't set the safc setting points lower than negative %10, then its nothing to worry about.
i'm running the car since approximate 3months with safc (highest negative point -9%), FCD, and 16psi of boost.
http://carpron.com/multisite/v/Upload/c ... =x398887c7
here you can see the table of timing changes... step by step.
good luck.
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
RoAdbOy
Postby underscore » Fri May 20, 2011 6:26 am
awesome, thanks. I may give it a try then. Would you say a FCD is a must have before doing any of this? Or is it only needed because you're running 16psi?
Also what kind of gains did you see? Anything significant?
Postby RoAdbOy » Fri May 20, 2011 7:38 am
FCD is only needed to run more boost then the fuelcut level of gen2 :) i use a fcd only to run 16psi.
the first thing you need to set the SAFC is a wideband afr gauge. you must read the numbers and set the safc point accordingly :) or you go to tuner for a dyno-tune.
my afr reading are without safc setting = sometimes 8.8afr / 9afr or 9.2afr.
but after a good setting the car runs now 11.5afr.
i can only say awesome response :D you can feel how faster the car now is.
with anything stock (9psi & 9afr) i tried a race from 2nd gear 60kph, with my other car, a civic vtec b16a2 and the celica wins by 3car lenghts. but after running 16psi & 11.5afr i can't see anymore the vtec in my mirror :D :D i thing it's more than 7car lenghts now.
when you tune it properly and not more than -10% i don't think it would be any problem.
good luck :)
Mehmet Ali Ovacikli
istanbul / TURKEY
RoAdbOy
Postby underscore » Fri May 20, 2011 9:53 pm
great info to have, thanks! I'm apparently good to 17.5 PSI so I'll leave out the FCD, now I just need to hunt down a cheap wideband and get my mechanic/tuner buddy to help me out.
