AFR & IAT Readings on stock St165 - everything ok?
Postby Bers » Tue Oct 18, 2011 5:00 am
Hi!
I'm on my way for my very first attempt at upping the boost on a car.
Before that, I'd like to hear your opinion on these readings, I'd just like to make sure everything is in proper working order before turning up the boost:
(rolling start, lazy shifts barely past 6000 rpm)
AFR: 11.0@4000rpm, down to 10.2@6000rpm, 7.8psi
IAT: 115-120F, outside temp was about 70F. Rises about 1.5-2.0 degrees per second on hard acceleration.
Car is bone stock except for a larger compressor trim and a decatted exhaust. No boost controller or hacks.
More questions :
- "USER1" signal is an analog input that I connected to check the TVSV Actuator signal from the ECU. Why would it stay on 5V then fall to 1.8V on boost? Seems strange, I was expecting more like 0V/5V. Furthermore, isn't this TVSV supposed to limit boost on 1st and 2nd gear?
- Boost used to drop down to 5-6psi@6500 rpm on 1st gear, and to 6.5-7psi@6500 on 2nd before the turbo compressor upgrade. I don't know if that upgrade was of any use, or if my old turbo was just tired. What do you think?
Bers
Re: AFR & IAT Readings on stock St165 - everything ok?
Postby BNZ » Tue Oct 18, 2011 7:13 am
Really nice graph's ! Good to see a stock W2A IAT's witch are in the "green zone" !
I have changed my W2A to the ST205 one. I will do a log on my Megasquirt and post the temps,just to see the differences on that IC change,although i think it will not be as big of a difference on a single straight line pull. The big difference is made on sustained racing like a special stage or circuit.
As for the TVIS,the system is active (valves closed under vacuum force) for increased torque in low revs and open after a certain rev (i've set mine to 3200rpm) the valves open under spring force (solenoid closes - low V - to bleed air) to increase airflow
L.E. On your graph it seems 4000rpm is the opening limit for TVIS
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby klue » Tue Oct 18, 2011 2:10 pm
numbers look good, nice and fat
