Pulling timing?
Pulling timing?
Postby aus jd 2703 » Tue Oct 25, 2011 5:19 am
Hey guys I'm starting to wonder if my engine is pulling timing so I'm curious how can I tell? Does the engine light come on? I've hit fuel cut and that's really obvious but I'm starting to worry I'm down on power because the ecu is pulling timing? I'm running a little bit more than the stock 10 base timing but only like 2 degrees as I'm running 98 octane gas. Has had a full service so should be running hard
aus jd 2703
Re: Pulling timing?
Postby concealer404 » Tue Oct 25, 2011 11:43 am
What car are we talking about?
Cars and stuff.
concealer404
Re: Pulling timing?
Postby Terracar » Tue Oct 25, 2011 1:38 pm
I had the same suspicion so I did the LED knock detection mod. It confirmed the knock/pulling timing.
http://www.celicatech.com/forums/showth ... A-TVSV-LED
-Terracar
Terracar
Re: Pulling timing?
Postby aus jd 2703 » Tue Oct 25, 2011 10:42 pm
ill look into the led mods rather cool.
its a st185 harness running a 205 engine and ecu so no afm or tvis etc
aus jd 2703
Re: Pulling timing?
Postby aus jd 2703 » Wed Oct 26, 2011 1:22 am
gave it a go and the led alternates red to green when on boost..????
aus jd 2703
Re: Pulling timing?
Postby coyoteboy » Fri Nov 25, 2011 4:32 pm
Just spotted this, which LED is it that's alternating? The 205 ECU uses, AFAIK, a PWM style boost control. If you're monitoring the boost solenoid you'll just flickering as it controls boost, which is normal, but if it's over-controlling the boost you'll struggle to identify it via visual means.
coyoteboy
