HKS Fcon
HKS Fcon
Postby concealer404 » Sat Dec 03, 2011 3:35 pm
Has anyone, or is anyone still successfully using this stuff on a 3sgte?
I ask because i have relatively modest power goals for my car, and i'm thinking an Fcon could probably handle up to that point. I know the Supra guys are able to get to almost 400whp using these setups.
Yes, i know it's outdated and that there's better options out there. But it's easy to use, and my current dealings with an EMS have left a REALLY bad taste in my mouth. (Hydra)
Was there a PFC made for both 2nd and 3rd gen 3sgte?
Cars and stuff.
concealer404
HKS Fcon
Postby captaingowa » Mon Jan 16, 2012 9:33 am
Not sure about the HKS FCON though I know you can get a Apexi Power FC from ATS Racing..
1988 Alltrac #0006073 Blue Pearl
4TH Owner: Purchased 26 March 2010
captaingowa
Re: HKS Fcon
Postby MrDB » Tue Jan 17, 2012 9:28 am
as long as its the fcon v pro gold it will cope with anything ony problem with it is mapping as only official HKS dealers / tuners should have the software
MrDB
HKS Fcon
Postby captaingowa » Tue Jan 17, 2012 12:29 pm
wow.. that sucks! There has to be software available to tune it yourself..
captaingowa
Re: HKS Fcon
Postby MrDB » Wed Jan 18, 2012 11:37 am
there is ebay :)
However its a complicated beast not exactly setup like other ecu's
Its a v.good ecu and can run as standalone which not many people know... Its also easy to do this with the 3sgte as it has the same connector as the stock ecu...
V big in japland and if you look its used on many big spec cars out there ( veilside etc )
MrDB
HKS Fcon
Postby captaingowa » Wed Jan 18, 2012 1:08 pm
As well the Power FC..
captaingowa
Re: HKS Fcon
Postby Mafix » Wed Jan 18, 2012 7:02 pm
first of all, the f-con only really works well with both the gcc and the vpc. and for that kind of money just get a real standalone.
and there is nothing wrong with a HYDRA ems. it is very powerful and well built and the ONLY plug and play for 165 harnesses. the problem lies in tuners and support. i totally agree that the support sucks. and tuning one is a nightmare. and that the hydra is way over powered (which yes is a bad thing), but:
i rank it in features with aem and haltech
i rank it the f-ing lowest on tunability (and yes i am a tuner as well)
i rank it up with haltech and motec for build quality
and again the f-ing lowest on support.
all that said, if haltech wasn't around and i didn't want to pretty much pay for a car again in the motec way, i would still be using a hydra. i'd take a hydra over any hks, apexi, or greddy product.
HKS Fcon
Postby captaingowa » Wed Jan 18, 2012 11:35 pm
Too bad the HKS Fcon does not have a larger community of users that can share information.
captaingowa
Re: HKS Fcon
Postby MrDB » Thu Jan 19, 2012 11:08 am
fcon
fcon-s http://1jzmerc.com/hks-faq/hardware/f-con-S
fcon-v http://1jzmerc.com/hks-faq/hardware/f-con-v-pro-silver
fcon anything but vpro gold
waste of money....
fcon v pro gold however is a full featured piggy back / standalone similar to the emanage ultimate but it can run without stock ecu as standalone also.
http://1jzmerc.com/hks-faq/hardware/f-con-v-pro-gold
http://www.hksusa.com/products/?id=1965
MrDB
Re: HKS Fcon
Postby lumbercis » Thu Jan 19, 2012 3:04 pm
If you already have a Hydra I'd just find a tuner that knows the box and can set it up for you. If the box itself is defective then Hydra should replace it. Sounds like we're only getting part of the story.
What are your power goals for the car?
J
Caldina powered...
lumbercis
HKS Fcon
Postby captaingowa » Thu Jan 19, 2012 7:03 pm
Yeah, it's best to have tuner that knows what their doing.
I have retracted my negative remarks since they were over opionated..
Hydra has been used very succesfully in many areas.. it's just a matter knowing the system.
captaingowa
Re: HKS Fcon
Postby mixer72 » Thu Jan 19, 2012 8:50 pm
i have the hsk f-con v-pro gold in my car and very happy with it work very well and will cope with what ever i throw at it :)
mixer72
Re: HKS Fcon
Postby concealer404 » Sun Feb 05, 2012 6:07 pm
Mafix wrote:first of all, the f-con only really works well with both the gcc and the vpc. and for that kind of money just get a real standalone.
I have a full PFC FCon setup on my DD, which is sortof what brought me to ask the original question. Works great, though the VPC is not an option with that particular car.
Hydra just pisses me off. I run 2.5 on my Miata. The support around here in terms of people who will touch it is slim to none. $275 wideband sensors can suck it, too. The start up and idle settings seem to be extremely hard to get solid, and the alternator output control (Mazda's fault, not hydra in this case) is garbage.
I'm probably going to end up with AEM since i'm no longer using a stock motor anyways, so the HKS stuff isn't really an option. Things have changed since i posted the thread 2 months ago. :P (stroker)
Cars and stuff.
concealer404
Re: HKS Fcon
Postby concealer404 » Sun Feb 05, 2012 6:11 pm
lumbercis wrote:If you already have a Hydra I'd just find a tuner that knows the box and can set it up for you. If the box itself is defective then Hydra should replace it. Sounds like we're only getting part of the story.
J
I should clear this up.
Daily driver: 1990 MX6 GT running PFC FCon with a Supra CT26 turbo. (srsly.)
Toy: 2004 mazdaspeed miata running Hydra 2.5
Race car: 93 Escort (will be running Megasquirt)
Celica: As yet determined...
Power goals: 350-400whp, but would be fun to be able to hit a 600whp "hail mary" on the dyno. Car is FWD. I have a couple things i'll be doing that might be viewed as "strange."
The box itself for Hydra is not defective, there's just a complete and utter lack of support, and i'm not comfortable tuning that particular car on my own, and looking at the software, i couldn't figure that shit out anyways. It's obnoxious.
Cars and stuff.
concealer404
HKS Fcon
Postby captaingowa » Sun Feb 05, 2012 9:48 pm
Haltech?
captaingowa
