Ok, so more problems with my EMS 8860....the tuning isn't going so well, in the words of my tuner, "this thing is rubbish"...there's a clunking sound coming from the fuel tank/pump whenever I have the car running off the EMS (at the moment I can switch between standard and EMS)...the factory ecu should continue to supply fuel as normal?, I mean it does, it just makes a clunking sound like a soleniod switching in time with engine rpm....you can only hear it at low revs, between 1000-2100....
