Afr reading
Re: Afr reading
Postby tubasteve » Thu May 03, 2012 1:34 am
A mbc can't "be set to", if you have consistent temps, then i could see this. When i ran mbc i would see 14 @ 85°, and 5 hours later @ 55° coos see as much as 16-17 psi. Bottom line watch/datalog your boost.
Aem gauges i believe can't read below 10:1.
Also didn't see a mls hg? Is be worried of blowing the head gasket around that boost.
tubasteve
Re: Afr reading
Postby jaydog82 » Thu May 03, 2012 3:54 am
Still running the stock hg, that's why I'm not going above 16 psi. I watch my boost like a hawk and it never changes, I did some research and found a high quality mbc that does not very.
Ya my gauge reads from 10-1 to 20-1
jaydog82
Re: Afr reading
Postby tubasteve » Thu May 03, 2012 4:19 am
i would get an aem "true boost" it can shut down the boost kind of like the stock pcm if it sees over boost, and log your boost, and be used with the plug and play. i have one on my red car, and if i raced or wanted to trick out my black car she would have one already. it really saved my ass one night.
i also would not mess with the maf. find another way to tune it, like an adjustable fuel pressure regulator.
tubasteve
Re: Afr reading
Postby jaydog82 » Thu May 03, 2012 4:24 am
I'm running a prosport electronic boost gauge with warning and prosport egt and prosport wide band.
Ya I'm not Gona mess with the maf, I might get a safc or just leave it better to be rich than lean.
jaydog82
Re: Afr reading
Postby tubasteve » Thu May 03, 2012 4:29 am
agreed, those are what i use in my black one. they are fine, but ive seen them tend to get off over time(boost gauges) my brother in law was messing around in his evo, never realized where the gaugue sat when off, it read "25psi"......the computer saw close to 35 when cyl #3 desided to take a detour out the side of the block.........then 20 mins later i met my wife for the first time :twisted:
tubasteve
Re: Afr reading
Postby jaydog82 » Thu May 03, 2012 1:57 pm
Nice
jaydog82
Re: Afr reading
Postby OutToWinPAHC » Sun May 06, 2012 2:22 pm
AEM has a new boost controller and wideband all in one called the fail-safe. It it goes to lean it will cut the boost and possibly safe the motor...... look into that it's pretty awesome.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Re: Afr reading
Postby Mafix » Wed May 09, 2012 4:31 pm
AEM = Another Electrical Mistake
lol
i'd go full 3" exhaust, and FMIC. leave the boost and the AFM alone. we'll talk after you get those done.
Re: Afr reading
Postby OutToWinPAHC » Wed May 09, 2012 6:25 pm
Mafix wrote:AEM = Another Electrical Mistake
lol
You may be crazy, I have used AEM, haltech, linkG4, Apexi PowerFC, Bigstuff, and OEM GM with HP tuners.... my AEM EMS series 2 is packed with so many options without the need to go buy other items. Boost control, anti-lag, two step, multiple ignition patterns, yada yada yada. Other than some motech controls I am very pleased with it. All for 1500 a few sensors and I'm very pleased.
OutToWinPAHC
Re: Afr reading
Postby Mafix » Wed May 09, 2012 6:53 pm
yes and my haltech has all of that too. what's your point? can't take a joke?
Re: Afr reading
Postby OutToWinPAHC » Thu May 10, 2012 7:47 pm
OutToWinPAHC
Re: Afr reading
Postby Mafix » Thu May 10, 2012 8:01 pm
exactly
Afr reading
Postby celigts » Thu May 10, 2012 10:15 pm
Would it be a bad thing to use an apexi safc? Would this help with my maf possibly being faulty?
3SGTE project motor very slow
celigts
Re: Afr reading
Postby RoAdbOy » Sat May 12, 2012 8:18 am
celigts wrote:Would it be a bad thing to use an apexi safc? Would this help with my maf possibly being faulty?
:) it depends on how you use it...
I drive my car since more than 3yrs with safc. I set it self and install it self. No problems :) but it can be horrible if you don't know how... You can damage the engine.
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
RoAdbOy
Re: Afr reading
Postby OutToWinPAHC » Sat May 12, 2012 11:34 am
I am not a fan of SAFC, but they can get the job done on a budget. I prefer other solutions such as a standalone which you can do for about 800+ depending on your level of comfortability.
OutToWinPAHC
