High NOx
High NOx
Postby crazyceli25 » Thu May 31, 2012 10:12 pm
I have a 1992 gt4 with 115k on it. I recently took an emissions test and passed on everything but my NOx
were too high. I was wondering, if someone here knows how this egr system works? The valve does hold a vacuum
but the control valve is allowing a vacuum when not being supplied power and closing when it gets power
Just didn't know if that's how it is supposed to be.
I tried searching with no results.
Any help will be appreciated.
Sean
crazyceli25
Re: High NOx
Postby Awesome-Trac » Thu May 31, 2012 11:14 pm
You live in Cali I'm guessing?
•Daniel
Awesome-Trac
Re: High NOx
Postby tubasteve » Fri Jun 01, 2012 12:04 am
Can't be, Cali does tsi, that tests hc/co
tubasteve
Re: High NOx
Postby tubasteve » Fri Jun 01, 2012 12:08 am
Also, the egr should be getting "ported" vacuum off the throttle body.
With the car running at idle apply 5 inches of vacuum and car should misfire horribly or die. Apply slow and evenly so that you don't flood the engine with egr giving you a false test. Also the buddy next to it (transducer) usually f fails also causing egr systems to fail functionality.
Very well versed in this.
-jr
tubasteve
Re: High NOx
Postby crazyceli25 » Fri Jun 01, 2012 7:05 pm
Thanks, I'll give that a try. How could it test the transducer to see if it has failed?
Sean
crazyceli25
Re: High NOx
Postby crazyceli25 » Fri Jun 01, 2012 8:41 pm
I gave that first test a shot. I only got to like 3 inches before it ran like crap
At 5 inches it didn't die but ran horribly
Sean
crazyceli25
Re: High NOx
Postby tubasteve » Fri Jun 01, 2012 9:11 pm
Good, get another transducer, 9 times out of ten is the problem if the flow is good.also taking the timing back a little from ten.
Where on earth are you having a awd tested for Nox? If it's not on a dyno might be hard to lower nox.
-jr
Goto wrecking yard and pick up Camry or other ones that look same. If not I'll type up the test when i get home.
tubasteve
Re: High NOx
Postby crazyceli25 » Sat Jun 02, 2012 1:45 pm
I live in CO
the testing stations here have AWD dynos
I'll go to the junkyard to find that
Thanks for the help
Sean
crazyceli25
Re: High NOx
Postby tubasteve » Sat Jun 02, 2012 8:32 pm
What are your other numbers for hc/co?
Plus what's all the limits
tubasteve
Re: High NOx
Postby crazyceli25 » Thu Jun 07, 2012 9:08 pm
HC: 0.5838 GPM Limit 1.5000 GPM
CO: 8.6759 GPM Limit 15.000 GPM
CO2 measured 410.9560 GPM
NOx 5.2602 GPM Limit 3.5000 GPM
Sean
crazyceli25
Re: High NOx
Postby tubasteve » Fri Jun 08, 2012 1:08 am
Was o2 measured?
tubasteve
Re: High NOx
Postby crazyceli25 » Fri Jun 08, 2012 10:43 pm
nope not on this one
Sean
crazyceli25
