Error Code 71
Error Code 71
Postby Jbob72 » Mon Jun 11, 2012 3:51 am
I have a 1992 all trac and my check engine light is constantly on when I drive. Today I checked which error code it was and it was error 71. The FAQ says that this is the EGR gas temp below acceptable level. I was wondering what I should do to go about fixing this problem. If I took out the EGR system would there be any way to test what is wrong with it or would I simply have to replace it? Any help would be appreciated.
Re: Error Code 71
Postby RoAdbOy » Mon Jun 18, 2012 7:21 am
you can still remove the whole egr system with block-off plates instead of replacing?
Mehmet Ali Ovacikli
istanbul / TURKEY
Re: Error Code 71
Postby Awesome-Trac » Tue Jun 19, 2012 3:41 am
I just got the same problem today except I just can't remove it cause I live in Cali and we require it to pass smog. So I was wondering can a cracked hose cause this problem?
-1988 Celica Alltrac (white) Sold
-1988 Celica Alltrac (black) new project
-1990 Corolla sedan (sky blue) totalled by my brother :(
-1990 Celica GT-S hatchback (sky blue) daily driver
Return to EFI Corner
