205 Ecu Conversion
Postby MIG407 » Fri Jun 17, 2005 4:41 am
chris would you be able to solderup a plug and play solution?
MIG407
Postby CMS-GT4 » Sun Jul 03, 2005 7:54 pm
Bump fo da topica
Postby **BETSY** » Fri Jul 07, 2006 5:13 pm
Indeed...
gathering parts to do this in my st165 ;)
Steve Gillies
ST-165 88 UK ([color=red]BETSY[/color])
[url=http://i32.photobucket.com/albums/d30/steve-gillies/Betsy/RollingRoad005.jpg]377BHP 353Ib/Ft[/url]
UK
**BETSY**
Postby ChrisD » Sun Oct 29, 2006 2:16 pm
I could easily, the problem is that I do not have a source for the plugs.
The conversion is pretty easy at the ECU end though. Only thing to keep in mind is that 1) TVIS will not work, 2) THAM has to be added, 3) THA has to be added, 4) need different turbo pressure sensor.
1988 ST165
1994 ST205 WRC
ChrisD
Postby Toxygene » Wed Nov 08, 2006 7:55 pm
bump. ETA on write-up? Also, does anyone know the part #s for the st205 sensors?
Toxygene
Postby **BETSY** » Wed Nov 08, 2006 10:01 pm
I have a spare IAT sensor and Mat sensor if any use?
Bid me happy ;)
Steve Gillies
UK
**BETSY**
Postby **BETSY** » Sat Nov 11, 2006 7:09 pm
Hi Guys, i have started again with getting the st205 system running on my st165/st185.
basically the car will start run for a couple of seconds and then dies.
if i touch the throttle it does even quicker!?
when it runs it sounds smooth and no miss fire.
There are no error codes at all.
I have disconnected the ISC and this makes no difference, on a 165 it should idle at 1k rpm.
FC wire has been cut from the COR and the wire has been connected directly to the Ecu COR ---> Ecu
tried running the car with the st165 Ignitor, no difference.
any suggestions, at a dead end :-(
Steve Gillies
UK
**BETSY**
Postby **BETSY** » Sun Nov 12, 2006 5:41 pm
Hi, had another crack at it today with a few results.
I found i had a few wires the wrong way around on the Igniter, no tacho, but have set them correctly and now tacho works fine.
It seems the car doesn't like to run or rev with the ISC connected!
if i disconnect it i can make the car rev which sounds smooth but it still won't idle?
on the 165 system if you disconect the ISC the car runs at 1k RPM as it should.
I get the same results running a st205 ecu as a rev3 ecu.
When the car does stall i can hear the fuel pump continue to run for 3 seconds after.
I bridged the AFM connector pins to enable the fuel pump to run full time, same has been tried in the diagnostic socket, and the car still doen't run any better.
I have a Fuel pump relay which was modified years back to run the pump @ 13V constant, again same results.
Adjusted the st165 Throttle position sensor to both extremes.. again same results
Unplugged O2 sensor... guess what ;) same results :-(
Again NO error codes, car fires on the button no problem.
Any one throw any ideas my way?
TIA
Steve Gillies
UK
**BETSY**
Postby Gary ST165 » Sun Nov 12, 2006 8:34 pm
hi Steve,
have you tried leak testing or replacing the isc valve?
datajon recently found a leaky isc valve caused similar symptoms as you describe...
hth.
Gary
ST165 turbo 4WD
Gary ST165
Postby **BETSY** » Sun Nov 12, 2006 8:43 pm
Hi Gary, I haven't swapped it out but the Idle was silky smooth running the st165 system?
wondering if i may have to run a st185 ISC, Throttle position sensor etc?
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Mon Nov 13, 2006 1:36 pm
I think part of your problems could come from the fact that the 185/165 ignitor is different from the 205 one. Now seeing as theres physically not much difference in the requirements of the engine I'm wondering if the 205 ignitor has some sort of jiggery pokery more than the 185 and the feedback signal to the ECU is not happening as teh 205 ecu expects it?
From my experience with the 'squirt this engine will idle under the most appalling conditions (7:1 fuelling, 19:1 fuelling, timing between 0 and 40 degrees at idle) so its unlikely to be anything other than incompatibility of components. Is the ISC valve wired the same way (RSC/RSO polarity)? It wont start if the ISC is shut, and it'll rev its balls off if its jammed open. (i managed to get mine to hit 5Krpm with just the idle valve open!)
coyoteboy
Postby **BETSY** » Mon Nov 13, 2006 2:47 pm
Hello Matey, Im using a st205 Ignitor, same symptons when trying to use a st165 Ignitor.
I also am using a st165 ISC which is a bit bigger than the 185 unit and the pins are labeled ISC1 and ISC2
the diagram shows the unit to be the same internaly as the 185/205 units but of course they are labeled RSC and RSO as you mention.
next parts to try are a st185 T/B with TPS and ISC
Big thanks for the replies :-)
much appreciated
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Mon Nov 13, 2006 2:52 pm
OK, thought you'd have covered that angle TBH but sometimes we all miss the obvious! ;)
I cant see too many other reasons for it not running right. If it idles ok for a few seconds then i cant see it being a TB thing, but that will iron out the possiblility of the ISC control setup i suppose. Keep us posted, im fascinated now lol
coyoteboy
Postby **BETSY** » Mon Nov 13, 2006 5:10 pm
Im curious as to how this system rellay works, purely by looking at the temperature of air by the air filter, intake manifold and vacuum/boost?
Yeah its almost like something is switching off after a couple of seconds?
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Tue Nov 14, 2006 1:03 am
The 205 speed-density system?
It monitors manifold pressure and temperature (the airbox sensor is only to judge ambient temps for reference) and looks at RPM. From the temp and pressure it knows the air density. From the RPM it knows the approximate flowrate. The maps are then tuned to correct for the inaccuracies in the relationship between theoretical airflow and RPM (Actually VE tables are Volumetric Efficiency maps, showing how well the cylinder fills with air at that RPM and pressure, and hence how much air you have at any one time).
This is why a speed-density system needs a remap with modifications whereas a flapper style AFM doesnt - if you improve your volumetric efficiency (what most mods aim to do) you screw up your mapping. The 185 AFM just measures the extra air and fuels to suit at those RPMs.
J
coyoteboy
