205 Ecu Conversion
Postby **BETSY** » Tue Nov 14, 2006 6:52 am
Hi J, makes sense , Thanks.
Sorted the problem...
I had a FCD fitted!
obviously a a car that isn't heavily dependent on a map sensor to work is fine, not so on a st205 system though!
The car starts, revs, idles and EVERYTHING! :-)
how do people run more boost on a st205 system? 17psi fuel cut?
Steve Gillies
ST-165 88 UK ([color=red]BETSY[/color])
[url=http://i32.photobucket.com/albums/d30/steve-gillies/Betsy/RollingRoad005.jpg]377BHP 353Ib/Ft[/url]
UK
**BETSY**
Postby coyoteboy » Tue Nov 14, 2006 10:18 am
17psi yes, but with the 20b turbo, id stick to 1 bar on a 26 unless your IC is good. AFAIK theres no way of getting higher than 17psi on the 205 due to the sensor being the fuelling sensor, no.
coyoteboy
Postby **BETSY** » Tue Nov 14, 2006 3:44 pm
Hi, I'm running a TT s148 turbo on a st205 charge cooler set-up coupled with twin Pace charge heat exchanger rads and W/Inj.
Intake temps are VERY low.
shall report back with how the test drive goes tonight ;)
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Tue Nov 14, 2006 4:44 pm
:) You running the 205 pump or the 165 pump in that? Which one is it you're offering to sell me on the OC :D My CS CC setup is "sans pump" and im dying to see what effect a decent setup has over the stock air to air topmount!
coyoteboy
Postby **BETSY** » Tue Nov 14, 2006 9:42 pm
I run the st165 Cc pump.
make a note to ones self, the st205 system is running 16' BTDC, dizzy has been left alone and the st165 system was running 10' :shock:
done a fair few miles in the car now and all seems good, shall try some more boost and report back ;)
Steve Gillies
UK
**BETSY**
Postby **BETSY** » Tue Dec 19, 2006 4:33 pm
Had a good result on the rolling road, 333BHP and 321Ib/Ft at 1.1Bar using the st205 based ecu system :-)
Steve Gillies
UK
**BETSY**
Postby CMS-GT4 » Tue Dec 19, 2006 4:43 pm
Did you get your code 54 sorted as well?
Postby **BETSY** » Tue Dec 19, 2006 4:46 pm
nope :-(
Steve Gillies
UK
**BETSY**
205 ECU repairs ?
Postby Alltracgt4Knight » Sat Dec 23, 2006 8:01 am
I work for a High guality electronics manufacturer.
I design, make and repair aerospace products everyday.
If you have a bad / damaged 205 ecu send it to me and I can try to repair it for you...
I can have the profiles for the IC chips and I can test / inspect your ECU
I am working on making new profiles to enhance the ecu's
These enhancements would include such features as
Remove / Update :
REV limit
Boost limit
Fuel cut level
Speed limit
I am working to incorporate the following adustible options.
shift / launch control
fuel gain control
over-rev control
Keep in mind - not all ECU's are repairible, My team would have to inspect it and decide on the nature of the damage.
90 Alltrac GT4 sold to BoostedBlueToyotas
ct26 group A/RC ceramic turbo
Whiteline Koni kit
Speedsource shift bushings/clutch line
Top End DP Saab core FMIC
92 4runner 7mgte turbo project
06 AWD Matrix auto for now.....
Alltracgt4Knight
Postby **BETSY** » Sat Dec 23, 2006 8:31 am
The main Issue with the st205 ECU is it throws code 54 due to there being no Charge cooler present, if converting to IC or ecu swap.
Certainly would be a worth while looking into it :-)
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Sat Dec 23, 2006 10:04 am
Steve - isnt that a simple case of lobbing a resistor in place of it? a code change to remove that seems a little drastic lol.
coyoteboy
Postby **BETSY** » Sat Dec 23, 2006 12:37 pm
J- Oh if it were only that simple!
No one.. has got over the code 54 on a car with out the stock st205 electrics in place as far as i know.
been there done that ;)
rev3 ECU was sooo much easier
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Sat Dec 23, 2006 3:41 pm
Rev 3? you mean Gen 3? Rev 3 is the 205 engine, gen 3 is the 165 car :)
I'm almost certain people on the OC had cured it? It cant exactly be hard - all you have to do is match the elec specs of the pump while knowing the wiring, its not an intelligent feedback type system.
coyoteboy
Postby **BETSY** » Sat Dec 23, 2006 3:46 pm
Rev 3+ MR2 ecu
Gen 1 engine= st165
Gen 2 engine= st185
Gen 3 Engine= st205
I use a st165 chassis and loom to run a Gen 2 Engine which in turn is controlled by a MR2 Rev3 ECU system.
The st205 ECU can not be fooled by running resistors as people have shown in various diagrams, i have tried several different configurations, along with a few others on here.
If you convert a st205 to run a FMIC then there are other systems in place which allow the 'Resistors' to do there thing.
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Sat Dec 23, 2006 4:00 pm
**BETSY** wrote:Rev 3+ MR2 ecu
Gen 1 engine= st165
Gen 2 engine= st185
Gen 3 Engine= st205
"gen" is usually referring to the body type, of which the 205 was a gen 6 (new ugly slow ones are gen 7). (http://en.wikipedia.org/wiki/Celica) Just clearing up confusion.
Suggesting Gens for the engine is a bad idea, as there were revisions *within* each body style as you know - different compression ratios etc across the 5th gen range despite being essentially the same engines from the same castings. Either way I know what you mean :)
Maybe im getting confused with the CS ecu which im fairly certain can, but im 99% certain ive *seen* a 205 with the pump removed by the local goon. What are you on about "other systems in place"?
coyoteboy
