205 Ecu Conversion
Postby **BETSY** » Sat Dec 23, 2006 4:08 pm
A st205 car can be converted to run a FMIC as shown on kris' web site and get over the code54.
This im lead to believe works fine.
There are obviously 'Other' systems in place, on the st205, by means of relays etc that allow the 'resistor' mods to work.
Myself and others have tried running a st205 ecu on their cars along with the resistors to no avail :-(
This leads me to believe the other wiring, relays etc are needed.
The Charge cooler is run by the st205 ecu where as the CS and st165 have a seperate ecu/relay box.
This is the very reason why i used the Rev3 MR2 ecu.
Steve Gillies
ST-165 88 UK ([color=red]BETSY[/color])
[url=http://i32.photobucket.com/albums/d30/steve-gillies/Betsy/RollingRoad005.jpg]377BHP 353Ib/Ft[/url]
UK
**BETSY**
Postby coyoteboy » Sat Dec 23, 2006 6:00 pm
Crack open the wiring diagrams and compare - should be fairly simple to see the differences and replicate them with some spare wire. Seems slightly odd to run a 205/mr2 ecu on a 185 engine purely because they're mapped for a totally different head, cam ,turbo and intake setup which will make BIG differences to the VE tables required. Certainly slight hardware tweaks knock the MS out of tune noticably in certain driving conditions, cant imagine how much a change of head would require a remap!
Anyway, each to his own :)
coyoteboy
Postby **BETSY** » Sat Dec 23, 2006 7:58 pm
J, I had my car on the rollers with the set-up i speak of and made 333BHP and 321 Ib/Ft torque.
this was at just under 1.1bar of boost and timing set to 10' BTDC.
I have a apexi power FC ready to go in and be mapped.
The main reason to do the conversion was to enable the use of the plug and play PFC as well as get rid of the AFM and use the next size injectors.
I use the st205 inlet camshaft.
If you do some digging there is a fair amount of info saying the st185 head design isn't as bad as many think ;)
imo the power figures speak for themselves as does the 'Butt' dyno :)
Steve Gillies
UK
**BETSY**
Postby coyoteboy » Sun Dec 24, 2006 11:57 am
Hell yeah im not disagreeing with you there - the power figures (or more impressively IMO the torque figure!) speaks for itself. I was just saying id be erm...concerned, thats all. If i could get that sort of power from mine I'd be a happy man! Must try on the rollers at some point but I seem to massively knock-limited for some reason. At least partly because of the gay topmount ive not managed to get rid of yet!
You do have most of the important parts of the 205 setup in there - did the cam make much difference? Did you have to change many shims or was it a complete shim/bucket swap too?
coyoteboy
Postby Wolf_Tm250 » Fri Aug 03, 2007 8:20 am
**BETSY** wrote:A st205 car can be converted to run a FMIC as shown on kris' web site and get over the code54.
+1
when I had stock ECU on my ST205 with FMIC and resistor in place, I got no 54 error code.
But exactly now, I made a 3SGTE Gen3 swap on a friend's ST202, we mount ST205 engine, ecu, engine loom, but NOT the 2nd engine vane loom ( the rightish ), and we are getting 54 error code even with ressistor pack and all the relais we had to have according to the wires map...
Wolf_Tm250
Gt-Four ST205 [2.34kg/hp DynoDynamics]
http://www.youtube.com/WolfTm250
DynoJet whp are false, and closer to other dynos FW hp. Please specify what dyno are your Whp from.
http://www.factorypro.com/magazine/dynojet_dyno_inflated_hp_reason.html
Wolf_Tm250
Postby **BETSY** » Fri Aug 03, 2007 2:53 pm
I never got around this, hence i run the rev3 mr2 ecu
Steve Gillies
UK
**BETSY**
Postby Wolf_Tm250 » Sat Aug 04, 2007 11:16 am
**BETSY** wrote:I never got around this, hence i run the rev3 mr2 ecu
Steve,
are you using a rev3 MR2 ecu with an ST205 engine and wire loom ?
Wolf_Tm250
Wolf_Tm250
Postby **BETSY** » Sat Aug 04, 2007 1:11 pm
Hi mate, its a 165 chassis and loom running a st185 engine which is controlled by an mr2 rev3 ecu.
333bhp 321 Ib/ft just under 1.1 bar of boost.
Steve Gillies
UK
**BETSY**
Postby Wolf_Tm250 » Sat Aug 04, 2007 7:41 pm
Hi Steve!
Sorry... I didn't understand...
Are you running a Power fc rev3 mr2 ecu (245 bhp) on a rev2 3sgte??
Did you have to do any mod to wires or connectors??
Wolf_Tm250
Wolf_Tm250
Postby **BETSY** » Sun Aug 05, 2007 11:04 am
Hi Wolf, No problem.
at the moment I'm running a Toyota stock MR2 Rev3 ecu.
I made up a plug and play patch lead to enable the rev3 ecu to plug straight into my st165 loom, everything can be reversed to run a st165 should i ever need to!?
reason for running the mr2 ecu at the moment is it enables me to simply plug in my power FC and get it mapped, very soon i hope!
I made a plate up to install the MAT sensor in the cold start injector location.
Steve Gillies
UK
**BETSY**
Postby Wolf_Tm250 » Sun Aug 05, 2007 6:27 pm
WOW Steve, you made a very very good job !!!
So I think you can give me a good advice on my issue...
as I told, on a friend ST202 where we swapped a 3SGTE 3rd gen, I'm getting 54 error code, even with resistor pack and relais, because we hadn't the engine vane loom, but only the engine loom...
Given that Power fc for ST205 is no more available, do you think we could use Power fc for MR2 3SGTE 3rd gen ?
I know it has electric steering control and TRC... are the connectors the same of the ST205 ?
Thanks !
Wolf_Tm250
Wolf_Tm250
Postby **BETSY** » Sun Aug 05, 2007 6:48 pm
Hi,
The ecu connectors are the same for the st205 and mr2 so i can't see it being a problem.
iirc it should plug in with out having to swap any pins around, bewteen the celica and mr2.
You will need to have some way of controling the charge cooler pump though, maybe a 12v ignition feed direct to the pump?
Steve Gillies
UK
**BETSY**
Postby Wolf_Tm250 » Sun Aug 05, 2007 9:09 pm
**BETSY** wrote:Hi,
Ok, thanks !
Yes, it's already in... :wink:
Ciao !
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Wed Aug 22, 2007 7:18 am
**BETSY** wrote:Hi,
Hi Mate...
just a note...
PFC for MR2 Turbo 3sgte 3rd gen arrived...
connectors are equal... BUT the engine goes on 3 cylinders...
Had a look on the connectors, and everything seems to be in the correct place/ no wires to swap...
Have you got any idea about this issue ??
Wolf_Tm250
Wolf_Tm250
Postby alltrac.net » Tue May 27, 2008 7:57 pm
Note:
For ST165/205 conversion, if you use the JDM intake manifold, it has the bung in the side (where the EGR would normally be) for the intake temperature sensor. The JDM harness also has a connector for it.
Just a tidbit.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
