205 Ecu Conversion
Postby Corey » Thu Jun 26, 2008 9:43 pm
Im very interested in getting a PFC.
My friend got one for his FD, and its amazing.
Does the MR2 PFC work with a '90 celica? 2nd rev engine
Corey
Images: 50
Postby Toxygene » Thu Jun 26, 2008 10:42 pm
Corey Darling wrote:Im very interested in getting a PFC.
What do you like about it? I've heard good things on NewCelica.org as well but no specifics.
Toxygene
Postby Corey » Thu Jun 26, 2008 11:01 pm
I've yet to see it in action actually. He just installed it a couple hours ago and called me about it.
His idle immediately improved, it displays coolant temp, air temp, controls boost, displays rpm (great for checking compression)
All kinds of cool stuff :)
EDIT: we just went for a drive. It also shows Knock response, ignition timing angle, revlimiters....
Corey
Images: 50
Postby Gary ST165 » Fri Jun 27, 2008 4:11 pm
SW20 Revision 3 Power FC can be made to work with any 3sgte. remove AFM and adapt to a MAP sensor system. it requires adaptor harness / repining and some rev3 sensors, or use aftermarket sensors and configure using the FC-datalogit.
or there are the very rare AP engineering / D-Jetro versions of the Power FC for the SW20 revision 1 and revision 2 which is near as damn it plug n play on the respective early and late spec ST185. NB, they were sold with an optional MAP sensor harness kit to eliminate the AFM.
ST165 turbo 4WD
Gary ST165
Postby Corey » Sat Jun 28, 2008 1:32 am
Great info :) thanks
Corey
Images: 50
Postby tubasteve » Sat Sep 27, 2008 5:00 am
is this post still alive? meaning, is this ecu swap been done on a 185? i have two options, 185 cs computer or cs 205 ecu...? what should i do, i hate flapper doors, just an fyi
tubasteve
Postby Meurz » Sat Sep 27, 2008 12:17 pm
tubasteve wrote:185 cs computer or cs 205 ecu...?
What? :shrug:
Turbocelica.nl
Meurz
Postby tubasteve » Sat Sep 27, 2008 7:04 pm
i just got two ecu off somepeople, i got the 89661-2b310 ecu(rc ecu) and the st205 ecu, i want to do this swap of no maf, can someone give me some light into this? or is there another site for this?
tubasteve
Postby Corey » Sat Dec 20, 2008 7:25 pm
Corey
Images: 50
Re: 205 Ecu Conversion
Postby BriinumsBo » Thu Jul 29, 2010 8:32 am
Gary, i have a PowerFC converted from SW20 to ST185 by Brash-Boy. i have just ecu and hand commander. do i need to add map sensor and intake temp sensor or is it compatible with AFM? i have 1990 st185, and the engine wont fire, i thought maybe the PFC is for 92-93, but now i wonder maybe its the MAP sensor im missing :/
BriinumsBo
Postby ohkay » Wed Mar 05, 2014 4:46 am
I'm about to do this conversion. just waiting on the injectors now.
"...because limits, like fears are often and illusion."
MJ
ohkay
Postby ohkay » Thu Mar 13, 2014 3:44 am
This goes out to people who may know. I did the conversion 2-3 gen. Used all the sensors everyone says using a berk jumper harness. The car turns on, idles for 30 seconds and then dies. Can't rev it. Any one have any tidbits they can throw my way?
MJ
ohkay
Postby soarer.jzz30 » Thu Mar 13, 2014 5:17 am
Check injector pigtail with noid light.
soarer.jzz30
Postby ohkay » Thu Mar 13, 2014 3:01 pm
Ok, fuel pump not working. I had to jump it and it ran fine.
MJ
ohkay
Postby phattyduck » Thu Mar 13, 2014 4:25 pm
ohkay wrote:Ok, fuel pump not working. I had to jump it and it ran fine.
Is your fuel pump resistor plugged in and working? The ST205 ECU runs the pump at full speed for a short time after startup then it will power the pump through the resistor at low speeds/idle...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
