205 Ecu Conversion
Re: 205 Ecu Conversion
Bro, I don't even know where that is. I'll have to look it up.
"...because limits, like fears are often and illusion."
MJ
MJ
- ohkay
It's all under the hood
soarer.jzz30 - Club Member
LOL... on the ST205, it attaches to the battery tray and looks like this:soarer.jzz30 wrote:It's all under the hood
Not sure on the ST185, but it should look very similar and have a 2-wire connector that goes to it.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck - Established Member
And the relay is to the left of the radiator. In a mini fuse box
The relay has the FP mod. I never disconnected the resistor, would that even matter?
MJ
MJ
- ohkay
So you have the pump running full time? If it's not running then I would assume that yes, something isn't right with your pump wiring
Alright!! Figured out that the circuit opening relay was crapped some how, replaced it and he's back in the game again!
MJ
MJ
- ohkay
Slightly off topic but im doing a st205 conversion on my st165,
I noticed that the st205 ecu has 2 different ecus from 94-95 and 96-99.
What r the differences. I got a late model engine and trans bht the wiring and ecu i got seprately were 95 ecu and harness
- mi645
