So I bought AEM's EMS-4 for my st215 powered Alltrac
Postby Tecker185 » Sun Aug 19, 2012 3:20 am
I got in last week, first thoughts are man this thing is small. At first I thought it was some kind of scam. I got it off eBay BNIB for $683 shipped, so I thought I'd been had.
When you buy the ems you get just the ems. No software no plug, a few instructions and some mounting hardware. The software must be downloaded via the website.
My only problem is why not include at least the multipin plug. Why sell a product that you can't install out of the box? I searched high and low to see if it came with a plug of any kind, no luck.
I got it running and idleing, I need to verify actual time verse what is read on the ems. Then I should be able to start tuning this thing.
I'm surprised the very little that is out there for base maps and info. I pretty much made my own base map, there isn't much for support.
I also could not get the software to work on my laptop. I have a Sony vaio windows 7 64 bit, it would install but if I opened any base maps it would give an error. I used my buddies laptop he has windows 7 32 bit, works flawlessly. Just an FYI before you buy download the software use some features and confirm it will work.
Tomorrow morning I hope to be able to drive the car. When I get a tune that I'm happy with I will post the calibration. I have searched high and low looking for something I could put in to start the car with with no luck. I will be more than happy to help anyone who has issues getting there car going.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Re: So I bought AEM's EMS-4 for my st215 powered Alltrac
Postby DeeCee » Sun Aug 19, 2012 3:50 am
Did you get a plug and pins then?
DeeCee
Postby Tecker185 » Sun Aug 19, 2012 3:54 am
Yes I got the multipin plug for an additional $100. Not to hard to wire up just need the ecu pinout, a lot of stuff isn't needed.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby camry90 » Thu Oct 04, 2012 12:38 am
i am looking forward to get mine!
camry90
Postby Tecker185 » Mon Oct 22, 2012 1:41 am
So Ive got the car running and I was able to drive it home. Ive attached my base map that should start your car. Everything is stock with the exception of a gm 3 bar map sensor part# 12223861.
Now is the long process of tuning and smoothing. This was all very new to me and frustrating experience. I hope this helps anyone who is trying use the ems-4 for there st215 swap.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby OutToWinPAHC » Mon Oct 22, 2012 2:24 am
Cool as I am going to use the same, however I have worked with a good bit of these and other AEM and that always come with the USB cable and AEM tuner software.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
