Supra Fuel pump confirmation.
Postby 3s_woob » Fri Aug 31, 2012 10:54 pm
I've been searching for a while and also reading on wolfkatz.com. Just want more confirmation on my understanding for my setup. I'm running stock ST-185H/RC injectors(cleaned), stock RC FPR, RC ECU,and RC AFM. Would it be ok to just run a supra fuel pump without getting an adjustable FPR? Would there be any negative impact fuel system and motor? Any EFI wisdom would be greatly appreciated.
Ryan
'91 ST-185 RC Conv.
'88 AW11 SC
Seattle, Wa.
3s_woob
Re: Supra Fuel pump comfirmation.
Postby wannabe toms racer » Fri Sep 07, 2012 9:24 am
I would speculate the supra pump to be slightly more powerful therefore with stock fuel system you might run into overfueling n possibly fouling out plugs n running too rich n all that stuff.. I would guess a nice aftermarket fpr wit a gauge might be in your best interests, at least till ya figure out your numbers, they're worth the security anyways. then maybe bigger injectors if need be.
That's just me though I could be mistaken.
Hope I helped maybe a little :D
Adam 'Akiba' Armstrong
90 audi 80 quattro- new projekt
Stubborn ass '91 alltrac - traded!
dont let ANYONE fool you money CAN buy happiness...
OR at least SUPPORT it...
wannabe toms racer
Images: 4
Postby 3s_woob » Fri Sep 07, 2012 3:02 pm
That does help. Thanks for the reply. I'm just going with a factory fp for now until I really figure out my hp goals and learn more about fueling applications.
Ryan
'91 ST-185 RC Conv.
'88 AW11 SC
Seattle, Wa.
3s_woob
Postby saved_1992 » Fri Sep 07, 2012 3:17 pm
iv had a supra pump in my car for 30k with stock fpr no problems. 46 trim on turbo 440 injectors and 3 " exhaust, g force ecu . have not fouled plugs at all, afr reading idle 14.7-15 area full throttle goes to 12-11 dont see any black smoke from exhaust either
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Re: Supra Fuel pump confirmation.
Postby 3s_woob » Fri Sep 07, 2012 4:42 pm
Yeah I've been seeing mixed reviews saying to beware of over fueling and people saying it's fine. I really haven't seen a definate answer on this.
Ryan
'91 ST-185 RC Conv.
'88 AW11 SC
Seattle, Wa.
3s_woob
Postby phattyduck » Fri Sep 07, 2012 5:01 pm
Over-fuelling might happen if you have disabled the two-stage fuel pump control circuit. If you have it in place, you should be fine.
I had a bit of a problem running rich on my (then stock) Camry Alltrac with a Supra Turbo pump, but it doesn't have the two stage fuel control circuit (stock 3s-fe).
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby underscore » Fri Sep 07, 2012 5:03 pm
If you have a wideband just watch your AFR's and see if you're running richer. If you are, get an adjustable FPR.
Postby 3s_woob » Tue Sep 11, 2012 1:58 am
So I decided to go with the supra pump and stick with the stock parts for now... will hook up a wide band just to keep an eye on my a/f ratio. if it is running too rich then I'll run a adjustable FPR. Thanks for the help guys.
Ryan
'91 ST-185 RC Conv.
'88 AW11 SC
Seattle, Wa.
3s_woob
