Autronic SMC and Air Conditioning woes
Postby melvinman2000 » Sun Sep 09, 2012 2:19 pm
I just had a autronic smc installed on my 5th gen and having ac woes. I followed the diagram here:
http://memweb.newsguy.com/~gtfour/autronic/install.html
I wired a 1kohm resistor inbetween from the negative ignition coil side to my ac amplifier wire where it used to be plugged into my stock ecu. I still cant get the compressor to fire up. Any suggestions? My ac magnetic clutch relay wire I don't think is wired up. Do I need to do anything with this?
Thank You
Stephen
melvinman2000
Re: Autronic SMC and Air Conditioning woes
Postby Hic » Thu Jan 03, 2013 7:08 am
You need to give rpm's to the ac amplifire. Just wire the black wire back, iirc, abd it works as stock.
Hic
Postby melvinman2000 » Mon Apr 22, 2013 8:15 pm
Sorry I know its been awhile but I am in need of AC since its been warming up here. What does IIRC mean? So black ignition wire to the ac amplifier is all I need?
melvinman2000
Postby phattyduck » Tue Apr 23, 2013 3:49 pm
melvinman2000 wrote:Sorry I know its been awhile but I am in need of AC since its been warming up here. What does IIRC mean? So black ignition wire to the ac amplifier is all I need?
IIRC = If I Recall Correctly
Yes, the AC amplifier needs to see the tach signal. You will also probably have to do some tuning and maybe an extra wire to the Autronic to turn up idle speed when the AC is on (this depends heavily on your exact setup).
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby melvinman2000 » Thu Apr 25, 2013 3:40 am
Charlie thank you so much for answering back.
Ok well I spoke with autronic and they told me to pull the tach signal off my msd 6. Can I just run the tach signal to the a/c (air compressor) wire on my old ecu harness or is there a specific wire on the ac amplifier itself I need to splice into.
Stephen
melvinman2000
Postby melvinman2000 » Wed May 29, 2013 3:48 pm
I wired the MSD tach output to the ac amplifier ignition wire. It tripped the ac clutch relay and then clicked on the ac compressor clutch and cold ac. However The issue im having now is it constantly stays on even when I turn off the AC button its still on, not good. It also isn't cycling. Any ideas?
melvinman2000
Postby phattyduck » Wed May 29, 2013 3:56 pm
Is there 12V at the compressor clutch (rather, does unplugging the compressor clutch wire turn it off)?
Any chance other AC related wiring was touched? The AC amplifier takes care of the rest of the control (temp control, cycling, etc.).
phattyduck
Postby melvinman2000 » Wed May 29, 2013 4:18 pm
The air conditioner worked before I had the autronic smc installed. After install it is not working so as far as wires are concerned the only wires that were touched should be the ones that were originally at the ecu for the air conditioner.
Unplugging the compressor will turn it off.
The ac amplifier wire I have hooked up to my msd rpm signal is #1 IG on the ac amplifier harness. Is this correct?
melvinman2000
