3SGTE ST215 Auto ECU on Manual Gearbox
Postby toyotafreak » Wed Jan 09, 2013 12:32 pm
Guys,
Is it possible to use the standard Toyota 3SGTE ST215 Auto ECU on a manual Gearbox ?
If so, what exactly would need to be bridged/changed ?
Will the management throw any error codes ?
Thanking you in advance for your assistance :)
toyotafreak
Re: 3SGTE ST215 Auto ECU on Manual Gearbox
Postby phattyduck » Fri Jan 11, 2013 4:29 pm
toyotafreak wrote:Guys,
I don't know this 100%, but since nobody else has answered... I believe the ST215 auto ECU will work fine with a manual transmission and won't throw any codes.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby toyotafreak » Sat Jan 12, 2013 6:11 am
Thanks for your response Charlie, much appreciated.
In South Africa when I bought the engine, this is what the guy said, but I wasnt sure if it was true, my transplant goes down in the next 2 weeks, so I will then know fur sure :)
Thanks again
toyotafreak
Postby Speedricer » Fri Feb 01, 2013 4:10 pm
I'm running the auto ecu with no problems
92 ST185 White
3" full exhaust
Megan Racing Springs
FMIC
st215 swap
Speedricer
Images: 8
Postby toyotafreak » Fri Feb 01, 2013 4:23 pm
Thanks speedricer, project almost complete and with you guys responses I now have peace of mind :)
toyotafreak
