AEM EMS tuned, ran fine, now trouble staying running.
Postby C-dubb » Wed Feb 20, 2013 10:11 pm
I had the AEM tuned on my all Trac a couple months ago and its been running fine. Drove it to work last week drove fine. After work it wouldn't start. Or it would start and not stay running. It sat for a day and I started it and it was running rich like 10:1 and like shit. Let it sit for a couple of days and started it up ran fine...for about 10 minutes then started running like shit again and died. I've checked wiring for the map sensor, wideband and everything seems in tact. I've checked intercooler piping and vacuum lines and everything is connected.
Any suggestions or thoughts? I'm at a loss.
Cory Wilson 1990 st185
C-dubb
Re: AEM EMS tuned, ran fine, now trouble staying running.
Postby klue » Wed Feb 20, 2013 10:25 pm
do you have a lap top with AEMPRO and AEM LOG
make a log file, and its easy to check the sensors from the lap top
Postby C-dubb » Wed Feb 20, 2013 10:45 pm
I do, but my ex grill friend has it. She'll probably be nice enough to let me us it though. Is there a certain feature I need to use? I'm not very familiar with it.
C-dubb
Postby klue » Thu Feb 21, 2013 12:47 am
you need to be able to hook up the lap top. You can verify the sensor inputs easily that way. If you can set up the logging it would be easy for you to send it and I can look at it and possibly help you.
99% of the time when something is off its mechanical issue. Go through the basics
spark fuel air
Postby Tecker185 » Thu Feb 21, 2013 1:23 am
I had a similar issue with my ems-4. Car would not start and when it did it ran rich as hell and like shit. I tried to connect to the ems and would not connect. I had to remove the neg cable for a few mins to reset the ems to be able to connect. Put the tune back in and would run good for a while then back to the same issue.
After tooling around for a bit on the aem forum. I fouled out that aem was having a software issue that they were trying to resolve. But in the meantime to put a password on the calibration.
I did that and have not had a single problem since. Best of luck to you.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby C-dubb » Tue Nov 19, 2013 6:28 pm
This ended up being a bad MAP sensor. I hooked up the laptop and looked at my sensor readings with the ignition on and engine not running. My MAP sensor was reading -15 something when it should have been at 0. Replaced the sensor and the problem was solved.
C-dubb
