distributor wiring issue
Postby bluntninja » Fri Mar 29, 2013 1:34 pm
Ok, I'm trying to finish put my 1991 all-trac back together and ran into a snag, one of several. I went to plug up my distributor and three of the four wires were disconnected.. I have the Toyota repair manuals and checked the wiring diagrams. The book says I should have L,B,Y,R (blue black yellow red ) in that order. The issue is my wires are green black yellow and red.. So I'm trying to check them at the ecu to figure out what's what. I should have a G2 G- Ne and G1. My issue is I'm not sure where the ecu is... Does anyone know what order the wires should go in?
bluntninja
Re: distributor wiring issue
Postby bluntninja » Fri Mar 29, 2013 2:16 pm
So I got some good light on the wires and my 'green' is blue. Still unsure of the order, is it from the front view of the plug of or the back? Here's a picture.
bluntninja
Postby l0ch0w » Fri Mar 29, 2013 4:14 pm
PM me... I have an easier solution...
Andrew
1991 Red Alltrac
l0ch0w
