wiring harness, over or under??
Postby bluntninja » Fri Mar 29, 2013 3:56 pm
I'm having trouble remembering how the wiring harness fits in by the starter. I can't recall if it goes under the starter or tucks in under the wastegate actuator above the starter. Here's a picture, I've pulled the starter so I have some room to work. As always any and all help is welcomed and appreciated!
Does it go over or under the starter? Any pictures or diagrams would be most helpful!!
bluntninja
Re: wiring harness, over or under??
Postby 88gt4DE » Fri Mar 29, 2013 8:08 pm
Def doesn't go under the starter ... Thought the black plastic went in back of motor threw intake ... what gen ?
Postby bluntninja » Fri Mar 29, 2013 9:32 pm
Gen 2 1991 This isn't the piece your thinking about. This is the part that comes up and runs to the main fuse/battery. box.
bluntninja
Postby jaydog82 » Fri Mar 29, 2013 10:00 pm
i believe it runs down on the top of the transmission.
jaydog82
Postby 88gt4DE » Sat Mar 30, 2013 3:34 pm
bluntninja wrote:Gen 2 1991 This isn't the piece your thinking about. This is the part that comes up and runs to the main fuse/battery. box.
Got ya ... Figured it must be different. Would there be any room for that between starter and trans case ?
