code 41 st165 after spark plug wire change. why tps?
Postby Anoo21 » Tue Jun 11, 2013 3:15 pm
Changed my spark plug wires and went to start my car and it barely started then died. Was really rough, then put my old spark plug wires back maybe the new ones were the problem but same thing. Check my wiring on the tps seemed fine and bgb said after testing the sensor ohmed out right. Do these sensor go out without notice because my car ran perfect when parked. I am leaning toward a vacuum leak, i used the search on the forum and all were about the st185 not st165 tps. Thanks
Anoo21
Re: code 41 st165 after spark plug wire change. why tps?
Postby Anoo21 » Thu Jun 13, 2013 3:59 pm
Bump anyone have any ideas I've done everything I think I can.
Anoo21
