Gen 3 injectors running gen 2 jdm ECU ?
Postby warracer » Wed Jul 24, 2013 2:08 am
I was wondering what would be the results,
way too rich, lean? Or could it work ?
Need you opinion here :)
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Re: Gen 3 injectors running gen 2 jdm ECU ?
Postby RedCelicaTRD » Thu Aug 08, 2013 2:22 am
Wayyyyyyyy to rich. Around 25% more fuel everywhere. If you had some type of fuel controller you could, but not on a stock ecu.
Postby warracer » Thu Aug 08, 2013 4:05 am
so say I currently run 13.5 while on full boost (way too lean) I could corect that by swapping the injectors so I would run closer to 10.2... right?
____________
ST185H A-Spec:
warracer
Postby mx6er2587 » Thu Aug 08, 2013 12:12 pm
car will run like crap everywhere outside full boost though, and will take longer to hit full boost (turbo spools faster the leaner the mixture)
I'm currently running a gt30 ball bearing turbo on a stock ecu with 550 injectors. Runs like shit. Swapping the 440's back in until I can get better fuel management.
mx6er2587
Postby klue » Thu Aug 08, 2013 8:02 pm
warracer wrote:so say I currently run 13.5 while on full boost (way too lean) I could corect that by swapping the injectors so I would run closer to 10.2... right?
Thats not the way to correct your problem. The 3sgte gen 2 ecu is already very rich, you will more than likely end up with bore was and oil dilution due to over fueling of gen 3 injectors. If you are intent on running them use the gen 3 electronics, the car will run much better over all
running 13.5 on stock pistons or any piston is a BAD IDEA!!!
Postby warracer » Thu Aug 08, 2013 9:01 pm
don't worry I am not running THAT lean I was just trying to understand how I could corect my problem :)
My car currently runs with NO O2 sensor what so ever, I just noticed that mine doesn't even work, I benched tested it with a flame and no voltage whatsoever came out, could that possibly be my problem?
____________
ST185H A-Spec:
warracer
