Can not find coolant level switch connector????
Postby Theman88b » Fri Aug 09, 2013 9:54 pm
I am trying to get rid of a code 54. I have an aftermarket fmic and I am trying to clear this code. I have found the water pump connector and now I am looking for the connector for the coolant level sensor so I can jump it. I thought it was by the left front strut tower but I can not find it. I have searched for a good picture of this connector with no success. I think it may be cut and hiding. Anyone help me with this issue? Good picture of what wire loom it is in? Thanks in adavance!!
'88 Toyota Celica All Trac Turbo(Blue) 145k - Rebuilt and Bored 1mm over, big psi soon!!
'92 Ford Taurus SHO(White) 212k - Some mods but still my DD
Theman88b
Images: 3
Re: Can not find coolant level switch connector????
Postby alltracman78 » Fri Aug 09, 2013 9:58 pm
I bet it runs to the ECU.....
Postby Theman88b » Sat Aug 10, 2013 2:44 am
The white/black wire runs back to engine control unit I believe and the pink/blue wire runs to the intercooler control unit. Am I just going to have to jump the wires at both units? I would rather just find the connector end and jump them together there. Any pictures of what loom it is on? I am working with a st165 with factory harness by the way.
Theman88b
Images: 3
Postby Theman88b » Mon Aug 12, 2013 1:29 am
Bump. Anyone???
Theman88b
Images: 3
Postby jaydog82 » Mon Aug 12, 2013 2:28 am
I can get you a pic later tonight
jaydog82
Postby Theman88b » Tue Aug 13, 2013 6:00 pm
Get a chance to take that picture?
Theman88b
Images: 3
Postby jaydog82 » Tue Aug 13, 2013 8:17 pm
Sorry not yet I'll get it on soon
jaydog82
Postby jaydog82 » Tue Aug 13, 2013 8:36 pm
I hope this helps
jaydog82
Postby brutekiller787 » Wed Aug 14, 2013 12:15 pm
it comes off the same bunch of sensor wires that go to the water outlet elbow off the head. hope that helps narrow the search
brutekiller787
Postby Theman88b » Wed Aug 14, 2013 6:19 pm
Yes that helps so much! Thank you!!
Theman88b
Images: 3
Postby jaydog82 » Wed Aug 14, 2013 8:02 pm
Glad to help
jaydog82
Postby Theman88b » Tue Aug 20, 2013 6:25 pm
Finally found the wires!! Had to open up the loom a bit to find where they cut them but yay me!!!
Coolant level sensor wires
Theman88b
Images: 3
Postby wakkjobb » Tue Aug 20, 2013 7:55 pm
I left it right around here...
and here's the left rail; it was smacked when I got it... :(
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby Theman88b » Tue Aug 20, 2013 8:22 pm
^^^Thanks for the pictures. Finally got the CEL resolved!! Did you extend the rail?
Theman88b
Images: 3
Postby wakkjobb » Tue Aug 20, 2013 10:08 pm
Nope; the bumper mounting holes were also elongated/drilled out when I picked it up... gotta love ghetto-fab body work.
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
