Issues not getting fuel to cylinder.
Postby Bryon » Mon Sep 16, 2013 11:42 pm
Fuel pump is pumping past the new filter. The plugs are fireing. But they are dry when I pull them out from trying to start it. Im guessing the injectors are not spraying. What can go wrong between the filter and the end of the injector?
I can keep it running with starter fluid through the intake. lookin for advise
Bryon
Re: Issues not getting fuel to cylinder.
Postby ___Scott___ » Tue Sep 17, 2013 2:29 am
Check your injector resistor pack to make sure there is power to it, and that the connections between it and the injectors is good.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
