Couple more questions? Fuel pump and map
Postby chevyok06 » Fri Nov 29, 2013 12:15 pm
So I am running 3rd Gen motor in my st165 with everything Idk about the fuel pump though and I am running a 2bar map sensor. My questions are: when I install my 3 Bay map sensor am I going to notice a difference immediately? Also is there any way to find out what fuel pump I have with it dropping the tank? Assuming it's stock for st165 had any one installed a walbro online 255lph instead of an intank and if so do you have to disconnect the original pump or, how does that work? Thanks in advance.
chevyok06
Re: Couple more questions? Fuel pump and map
Postby chevyok06 » Sat Nov 30, 2013 3:27 pm
Any one?
chevyok06
Postby Mafix » Sat Nov 30, 2013 11:02 pm
are you running 3rd gen electronics? a pic is worth a thousand words.
you have to drop the tank. don't install an inline pump. just drop the tank and do it proper.
