3sgte timing maps- what are you running?
Postby heller » Sat Feb 01, 2014 7:49 pm
im looking for timing maps, how much boost your running, and horsepower and torque numbers if you had it dynoed. also any other mods you have done. i have my mod list in my signature, and im running 15 psi. i need some maps to give me an idea what i can run to pick up maximum output for my setup. thanks in advance
91 clelica gts gen 2 3sgte swap , 5spd, gt3076r,hks bov hydra nemesis 2.7 , wiseco pistons, eagle rods, 880cc injectors, 270 degree kelford cams.
heller
Re: 3sgte timing maps- what are you running?
Postby Mafix » Sun Feb 09, 2014 9:58 pm
i don't think anyone will divuldge such info. 2 degrees can pop a motor in the wrong scenario. there are far too many factors to give you a number. you need a tuner and a dyno. not a forum.
Postby heller » Tue Feb 11, 2014 6:51 pm
true, i was hoping for a guide line to help save time on the dyno, i found some, so thanks anyway
heller
Postby psipwrd » Tue Feb 11, 2014 7:05 pm
The closest awd dyno to me with AEM tuner is in switzerland, a 6 hr drive. What kind of advice do you have for someone like me who have that long a drive? Are there any tuning tips or rules for road tunes?
psipwrd
Postby C-dubb » Tue Feb 11, 2014 10:09 pm
psipwrd wrote:The closest awd dyno to me with AEM tuner is in switzerland, a 6 hr drive. What kind of advice do you have for someone like me who have that long a drive? Are there any tuning tips or rules for road tunes?
for street tuning...hit record... WOT pull in third gear...watch afr's...adjust for increase in power...repeat.
Cory Wilson 1990 st185
C-dubb
Postby underscore » Tue Feb 11, 2014 10:11 pm
Find a 2WD dyno and put the transmission in FWD mode.
Postby GT4_DRED » Wed Feb 12, 2014 12:20 am
I'm still fairly new to tuning my setup and prefer to back into timing. My personal rule when starting off is 15psi max for 92 pump, pull 1 deg/timing per psi/boost and keep a check on the plugs. I usually work the 0-5, 6-10 and 11-15 psi ranges incrementally. That's usually a conservative approach that works for me and my setup.
'00 SC300 - "Big Butt"
'88 ST165 - "Rahtid"
'88 ST165 - "Supah Cyat"
'88 ST165 - "Cornbeef"
'88 ST165 - "Redhead"
'91 MR2-T SMG
'92 MR2-T Nautical Blue
GT4_DRED
Postby klue » Wed Feb 12, 2014 1:17 am
best rule is not to mess with it. Map the timing super conservative, stay out of boost. Tune the fuel until you can get it driving smoothly and take it right to the dyno. Better yet, get a tow truck there and let the pro's do it.
you dont want to spend time and money building a motor just to have it blow up because you rushed the last step.
Take it from me, with a grain of salt. Having tuned my share on street dyno and track. Its better just to get it done right, and fast. I've also blown up my share of motors when I was starting up, chalk that to the learning curve.
Postby Mafix » Sun Feb 16, 2014 10:44 pm
agreed. plug reading is good for afr on an n/a motor. not so great on a pump gas tuned boosted motor. and i'm not sure how you can check timing with a plug read. if you see detonation marks on the plug, you should have already caused horrible damage to the pistons.
use the aem base map for a 3sgte. they have them. get it remotely drivable and straight to a tuner/dyno.
