Gen 4 tach signal
Gen 4 tach signal
Postby 3spowerhouse » Wed Feb 05, 2014 9:02 pm
I'm sure most people know the factory tach doesn't work after doing a gen 4 swap, how have most people rectified this problem? A tach adapter can solve this but has anyone ever used any other alternatives? I've read that a 10k ohm resistor can make it functional again, anyone tried this?
3spowerhouse
Re: Gen 4 tach signal
Postby fussellbug » Thu Feb 06, 2014 8:52 pm
The Caldina 3S-GTE probably has the same tach signal as the Beams 3S-GE. Some Beams owners have used a resistor to correct for the difference.
http://www.mr2.com/forums/threads/82165-BEAMS-tach-and-AC?highlight=tach+resistor
fussellbug
Images: 36
Postby 3spowerhouse » Fri Feb 07, 2014 12:05 pm
yep, this confirms it Image
3spowerhouse
Postby pit_celica » Sat Feb 08, 2014 6:12 pm
I built my own tach adapter using a standard bosch coil relay and a transistor as seen in this thread :
http://www.mr2oc.com/showthread.php?t=436425
It worked nicely.
Sam
1991 Toyota Celica GT-S ST184 with 3SGTE gen4 ST215 swap, Megasquirt 3 + MS3X, t3/t4 turbo, 3" full exhaust, front mount intercooler and more for fun !!!!!
pit_celica
