I am tring to bypass my knock censor singnal short code (52). I have fixed this once before, i dont know why im still getting the code, thanks
Please PM me
Maybe the wire to the sensor is bad, mine was. I have a roll of the aviation grade shielded wire if you need some. The shielded wire breks down with age causing false codes sometimes due to rf interferance. 7mgte supras are notorious for this. Just replace wire from sensor to ecm and ground the shielding at the ecm.
