How the ECU knows the gearbox is in 1st/2nd gear or 3rd & up
Re: How the ECU knows the gearbox is in 1st/2nd gear or 3rd
Postby MWP » Mon Mar 24, 2014 9:37 am
AvivB wrote:TVSV open when throttle is open wide enough...
I don't think it related to air volume as it can open on low rpm without boost (low air volume) and it can be closed in high rpm (high air volume).
You sure about that?
It shouldnt do.
Postby AvivB » Mon Mar 24, 2014 9:43 am
I saw it open in less that 2000 rpm and closed when you release the throttle at 6000 rpm...
/Aviv
('92 ST182RC 1/1 :-) )
AvivB
Postby underscore » Mon Mar 24, 2014 2:51 pm
So the light will come on even when the car is still in vacuum? If you can confirm this you can save me a lot of work.
Postby AvivB » Mon Mar 24, 2014 6:17 pm
If the throttle is open so there is no more vacuum... :)
It turns on when the pressure is around 0 (zero) and turns off when it drops bellow around -5inHg (low vacuum).
What are you trying to do that you want to use this signal?
/Aviv
AvivB
Postby MWP » Mon Apr 07, 2014 10:12 am
AvivB wrote:If the throttle is open so there is no more vacuum... :)
... thats why there is a TVIS vac reservoir.
It can be activated without there being vac in the inlet manifold.
Postby Simba » Mon Apr 07, 2014 7:31 pm
In that context (and most others) the ECU cares about engine load and little else.
Lots of fast, loud things.
Simba
Postby AvivB » Tue Apr 08, 2014 5:35 am
Yep, I'm well aware about the TVIS vacuum reservoir...
It activated at low rpm and released at 3k rpm so it need something to keep it open at the beginning of the acceleration when throttle is wide open (in some cases).
/Aviv
AvivB
Postby AvivB » Tue Apr 08, 2014 5:38 am
Simba wrote:In that context (and most others) the ECU cares about engine load and little else.
Not sure I understand what you mean...
/Aviv
AvivB
Postby zf_165_gt » Tue Nov 25, 2014 2:18 am
the engine load: He meant it depends on the AFM readings and engine rev at that time.
and yeah the ECU senses car speed. the highest sustained engine loads are recorded when the car moves faster, it could be only engine load related. we could prove that with readings :twisted:
1988 ST165 , clean body, broken engine since acquisition.
1991 ST185 JDM , CT26/CT20 hybrid,
zf_165_gt
